late 1st gen grille
Old Mar 12, 2008 | 10:31 PM
77machomopar's Avatar
late 1st gen grille
I want to use the 1991-1993 grille instead of the older 80's grille. I know i will have to get a new core support. Since i am using a 1988 gasoline core support i know it wont work, but will any diesel core support work or does it have to be 91 and up? If it has to be a diesel support anybody have one to sell or trade? Could I use a 91 and up gasser support? thanks
Old Mar 12, 2008 | 10:44 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
the newer grille should bolt in place of the older grille
Old Mar 12, 2008 | 10:48 PM
Alwaysworking's Avatar
alwaysonDTR
what about the under grill body peice, my 82 and 91 are way different. so i would guess, that would be the only peice you might have to change.
Old Mar 12, 2008 | 11:01 PM
GO OVRIT's Avatar
The headlights are in the wrong place. You'll have to get a 91 & up support.
Old Mar 12, 2008 | 11:10 PM
alwaysonDTR
couldn't you move the buckets?
Old Mar 13, 2008 | 07:54 AM
Move buckets
The buckets are completely different set up and location. i would have to do allot of fabing. it would be easier to get a 91 and up core support. Anyone got one?
Old Mar 14, 2008 | 10:54 PM
Bogie's Avatar
Its not that had to modify the early rad support
Mopar Muscle How To
Old Mar 15, 2008 | 09:55 AM
rebal's Avatar
it is easyer to find a core support then you would be set to intercool
later on. I just did a non intercooled to intercooled conversion and it was easyer then when i tried to mod everything on another rig. and it is a cleaner setup
Old Mar 16, 2008 | 08:45 AM
sooty's Avatar
old grill
i set mine up with the banks i/c and used the later grill, cut and welded the buckets higher, snuck some screws through the edge of the headlight bezel, to hold the side tight, now ive got the larger ps i/c to modify in, hoping to get the condenser out front of the i/c to compete with the so. cal. heat. theres a lot more room behind the later grill. good luck!
Old Mar 17, 2008 | 12:47 AM
flashgordon's Avatar
Mopar Muscle How To
thats a grate link...........Hope you don't mind me adding it to my write-up
Flash
Old Mar 17, 2008 | 12:49 AM
Bogie's Avatar
Not at all It helped us do a few grill upgrades. Now I just hope to upgrade mine with a rad support with a Intercooler
Old Mar 17, 2008 | 06:32 AM
KartRacer's Avatar
It doesn't need to be a diesel core support if you don't plan on intercooling. Even if you do intercool, if you don't mind doing some cutting it would be fine.
92GhostRyder
Sep 16, 2018 12:02 PM
willroach
May 30, 2014 05:54 PM
Hodge
Feb 13, 2010 01:05 PM
92smokin blacky
Aug 27, 2009 04:27 PM
