KSB solenoid needed
Old Jan 20, 2005 | 05:35 PM
vavtx's Avatar
KSB solenoid needed
Anyone have a KSB solenoid they want to get rid of? Maybe off an old pump or junker sitting around. The cheapest I can find a new one is $180.00.
Old Jan 20, 2005 | 05:39 PM
How did you determine the solenoid is bad? The assembly can be removed from the pump, disassembled and cleaned - if something is gummed up that will cure it.
Old Jan 21, 2005 | 04:28 PM
vavtx's Avatar
I jumped 12 volts to it and did not see a difference in the way the engine ran when cold.
Old Jan 21, 2005 | 07:45 PM
Pull the housing off the side of the pump and disassemble it to make sure the valve isn't gunked up. Also, while you have it apart, put 12 volts across the solenoid and watch to see if the plunger moves. If it pops out with no help, it;s OK.
92smokin blacky
Jul 17, 2012 01:33 AM
Farmall
Dec 9, 2011 10:03 PM
59FORD
Feb 26, 2007 06:44 AM
TexasBlake
Dec 15, 2004 08:48 PM
Farmall
Feb 26, 2003 03:58 PM
