what kind of HP can I expect?
Old 01-16-2008, 05:45 PM
Ru rammin 2?'s Avatar
My mods are in the signature. gonna set the timing at 16*. also got a bhaf.
Old 01-16-2008, 11:21 PM
Lil Dog's Avatar
With a stock turbo, you are gonna be hamstrung to around 350-375 RW. IMHO.. Even at that the pyro will need a 5th digit..
Old 01-17-2008, 12:22 AM
95dodgectd's Avatar
which plate did you grind? probably closer to 350hp maybe. depends on what plate you have and if its full foward or in the center
Old 01-17-2008, 10:44 AM
its a zero plate full forward. what does the RHP translate to at the crank?
Old 01-17-2008, 04:16 PM
stirpicult's Avatar
divide the RHP by .70 and .80 and you will have ballpark...so 440-500 ish.
Old 01-17-2008, 07:33 PM
BigErksG2's Avatar
these numbers might be a little high. with a stock turbo you can only clear up so much fuel. if you add more fuel past the efficiency point you are "putting out the flame" and losing power. saw it happen first hand, person dynoed, swapped injectors, dynoed again and lost 40hp. tuning is key and the timing should really help up top.
Old 01-18-2008, 03:23 PM
Lil Dog's Avatar
Just from experience, I put down 330 with stock 215's and stock HX35 running around 38psi boost. I was thinking with the GSK and few other mods you might get another 20 ponies out of it. I haven't hit the rollers yet with the stuff I changed out.
68rs327
07-24-2011 06:48 PM
Totallyrad
07-19-2011 07:41 AM
nasty01cummims
05-23-2009 10:24 PM
BrandonB9
07-31-2008 03:07 PM
clydesdale6
01-22-2003 06:10 PM
Quick Reply: what kind of HP can I expect?
