Just changed oil and trans fluid/filter... now stalls??
Old 02-23-2010, 10:36 AM
ClackClack's Avatar
Hi all,
I'm puzzled by this problem. I just changed my oil and filter, fuel filter, and transmission fluid and filter as a part of scheduled maintenance. Everything went as routine, nothing unusual.
Twice now, since doing this, the engine has stalled unexpectedly but both under identical circumstances.
Both times the truck has stalled have been after hard acceleration, then sitting at a stoplight. The engine idles a little rough, then when I depress the accelerator, the engine stalls. It will restart and idle, even rev up in neutral and the idle in gear. As soon as I press the accelerator pedal, it stalls again.
I was able to shift it into 4 low and idle it into a parking lot, but shortly after all went back to normal.
Thoughts? No codes, no prior issues. This truck has never been in the shop for anything that wasn't routine maintenance. It's also bone stock except for straight exhaust. I've not yet verified the LP running, but will do that as soon as I get off work.
2004 2500 California Emmissions
Please help!!
Old 02-23-2010, 10:39 AM
Lost Lake's Avatar
Gotta be the fuel.
Old 02-23-2010, 10:47 AM
ClackClack's Avatar
Yeah, that's sort of what I was thinking. 95,000 miles on the stock filter-mounted lift pump... I bet it's toast.
I just wanted to make sure there was nothing I could have done to the transmission or otherwise that would cause this behavior.
Old 02-23-2010, 10:51 AM
gcssr's Avatar
did you install " o" ring in the groove in the fuel filter cap ? could you of possibly overtorqued the cap and cracked it ? just a few things to check.
Old 02-23-2010, 12:04 PM
ClackClack's Avatar
Thanks. I'll check it, but I'm pretty sure that stuff is okay. I'll have a look just to be sure.
Old 02-23-2010, 12:41 PM
bansh-eman's Avatar
How long does it do this before it runs like it should? I was thinking maybe you just got some air in the filter housing or hoses and it is clearing it out???
Old 02-23-2010, 12:59 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
I would pull fuel filter take a flashlight and look in bottom of fuel filter housing. Is there sediment in the bottom of housing? You may have just stirred it up when you put your filter in and some got up into injectors or FCA. If you still have your stock fuel pump on the fuel filter housing that could be another problem also. Verify proper low pressure fuel supply to the injection pump: the in-tank transfer pump. In a good low pressure fuel system, fuel flow of 560 mL in
10 seconds or better is expected for model years 2003 and early 2004. The fuel
volume for the model years late 2004 through 2007 is 590mL in 10 seconds. Be sure
there is no air in the system.
Old 02-23-2010, 02:50 PM
ClackClack's Avatar
I'm hoping it will hang on long enough to get it home. I'll post up what I find this evening.
Thanks for all of the suggestions; I'm glad to have a starting point!
Old 02-23-2010, 02:57 PM
billie's Avatar
Likely the best answers are above but you could check for any electrical connections that may have been disturbed. That would probably get you a code though. My money is on the LP.
Old 02-23-2010, 03:22 PM
tlloyd's Avatar
Originally Posted by ClackClack
Hi all,
Please help!!
You do have a fuel problem. Since you changed the fuel filter I would start there.Did you replace the "O" ring on the filter cap.? Did you overtighten and crack the cap? These are just suggestions, Just start with the simple things first and do'nt panic. When you panic it gets expensive. I take it that everthing was fine until your oil change ,fuel filter change and tranmission service.I bet if you look carefully you will find the issue.I would also bet its not as serious as you think it is.
Old 02-23-2010, 05:07 PM
ClackClack's Avatar
Thanks. I'm not in a panic yet... lol
It set a P0628 on the drive home. It's lift pump time. I bumped the key and the pump doesn't run.
Old 02-23-2010, 05:14 PM
bansh-eman's Avatar
Look into the Raptor. They are rated for 16,000 hours. And they do not require a fuel return line like the airdogs.
Old 02-23-2010, 08:16 PM
ClackClack's Avatar
Sincerest thanks to all of you. I just finished changing the lift pump and all is back to normal. The old one was completely dead. I followed all of the advice above and I feel a lot better about having fixed it myself. Thanks!!
I replaced with a Napa direct-replacement since I needed it fixed right away and I live close to the Napa distribution center (it's nice to hear them say "I have it" instead of "I can get it for you tomorrow"!) I realize this isn't a permanent fix, but hey, I got 95,000 miles out of the first one, right?
Now, on to the 'lamp out' issue.....
Cheers!
Old 02-24-2010, 09:12 AM
Lost Lake's Avatar
Thanks for following up, and glad you got it running!!!
Geico266
22
11-23-2012 09:43 PM
slowstang232
09-04-2008 09:15 PM
Hounddog
02-14-2006 06:33 PM
fitzydog
04-21-2005 09:04 PM
MIKE,J
08-29-2003 09:26 AM
Quick Reply: Just changed oil and trans fluid/filter... now stalls??
