just changed the lift pump, and now am throwing codes...HELP!!!!
so the truck left me stranded (for the 2nd time in two months) on monday evening with code P0628. today my lift pump came in, i changed it, now the truck runs again...yay.
but now i am throwing P2146 and P2149. what is going on here? i need to take the truck on a 400 mile round trip this weekend (leaving tomorrow). is this a quick fix or is there something seriously wrong? it seems to run just fine.
so i went to the auto parts store to find out what the codes were...i couldnt find P2XXX codes online. im assuming its nothing major since im not getting a CEL, but still it bugs the crap out of me that something is not the way it should be.
P0628 - Fuel Pump A Control Circuit Low
P2146 - Fuel Injector Grp A Supply Voltage Circuit Open
P2149 - Fuel Injector Grp B Supply Voltage Circuit Open
P2146 Bank 1 (Cylinders 1-3) Shorted High Or Low
P2149 Bank 2 (Cylinders 4-6) Shorted High Or Low
A quick google as I know nothing about 3rd gens says it's passably a nicked wire on the internal injector harness. Done as you replaced the LP??? one case was done with head studs nicking the wire but it's electrical.
**edit**
Always look for your codes on the DTR WIKI found just below the Other forum. Much info in their.
Good luck.
**edit**
Good luck.
Darrin F.
May 26, 2010 09:57 PM
User Name:
16
Sep 18, 2009 06:25 PM
RAT_03
Apr 1, 2007 03:51 PM
