Interior plastic color
Old 10-19-2009, 08:27 AM
tjs88yj's Avatar
How do I know the Dodge name of the interior plastic parts of my dash? Agate? Black? Tan? Is there a code to identify the specfic color? It's the truck in my sig. Thanks
Tom
Old 10-19-2009, 10:13 AM
kreynolds's Avatar
I'm not sure where you can find the code, but I have the dark gray interior in mine and it is "agate".
In 2001 there were three color choices(not sure if they are the same as 98).
Dark gray or charcoal is called AGATE.
Tan is called CAMEL.
Light gray is called MIST GRAY.
Hope that helps.
Old 10-19-2009, 11:47 AM
tjs88yj's Avatar
Thanks, I guess I have agate since I don't have tan or light gray. The Dodgeparts website lists Agate, Cirrus, and Suede as the 3 colors, I figured I had either Agate or Cirrus which is the light gray I guess.
Tom
Old 10-19-2009, 12:09 PM
high bid's Avatar
Hope that helps.
Cummins engine paint color camel matches the interior well if the "exact" interior paint can't be found.
Old 10-19-2009, 04:32 PM
recklesskelly's Avatar
Geno's has exact match interior Mopar paint
http://www.genosgarage.com/products.asp?dept=98
Old 10-21-2009, 01:47 PM
ghenges's Avatar
Trim Codes
Trim Code can be found on the radiator support or under the passenger seat on 1998-2001 Dodge Rams.
Just replaced my 2000 Ram 1500 dash cover with a new one from Dodge. Color was close but not quite right, Dupont dealer mixed a pint of interior paint (code LAZ for Agate), $45 bucks but it matched perfectly.
I suspect all Dodge interior plastic is factory painted because the finished side of the dash cover was not close in color to the underneath side.
Here's an interesting link where I obtained the below image:
Old 10-21-2009, 05:33 PM
Dr. Evil's Avatar
Hope that helps.
The original poster has a 98 - Its MIST GREY. The newer trucks switched to the darker Agate color.
Old 10-21-2009, 07:59 PM
tjs88yj's Avatar
I found mine on the under side of the hood, Thanks for the information on the codes.
Mine is definately NOT mist gray it is almost black (actually I thought it was black) according to the code on the sticker it is R1AZ Agate. I have the 'new' style 98 interior.
Tom
Old 10-21-2009, 10:39 PM
Dr. Evil's Avatar
It depends on what plastic you are talking about. I assumed that you were talking about painting the pillar.
And I have the "new" interior on a 98 and its mist grey.
Old 10-22-2009, 08:49 PM
ghenges's Avatar
Tom
If you intend to paint interior trim parts, I would highly recommend the Dupont interior paint despite the high cost.
Not only did the agate color match exactly, so did the gloss (or sheen).
The painted upper dash cover couldn't be distinguished from an original factory dash.
smokinram99
04-27-2008 11:09 AM
possum
09-06-2005 08:39 AM
mt72916
02-01-2005 08:00 AM
ClawHammer
06-28-2004 01:46 AM
Quick Reply: Interior plastic color
