instaled blue pump
Old Jun 6, 2006 | 08:14 PM
edy's Avatar
edy
instaled blue pump
got my blue pump instaled love it had to run a regulator i had 26 psi with out it 18 psi with it at idle i love it if i could get all the leaks taken care of
Old Jun 6, 2006 | 08:27 PM
BigBlue's Avatar
You must be running the stock lift pump as well cause all I get unregulated with my blue by itself is 15 at idle and 11 at WOT. Been running it for almost 3 years now and it's still holding that pressure.
Old Jun 7, 2006 | 09:51 AM
edy's Avatar
edy
what do i do about the leaks i used npt fittings i just keep tightening them and the leaks slow down a little bit i thought i had all of them taken care of till this morning i crawlled under the truck and there is a slight leak aruond the fittings
Old Jun 7, 2006 | 12:50 PM
blackdiesel's Avatar
Registered
thread tape? you did use it right?
Old Jun 7, 2006 | 01:08 PM
Rauschbo's Avatar
Thread tape??
You should use a thread paste on fuel lines! (Just repeating the admonishment given to me when I purchased my gauges)....
Old Jun 7, 2006 | 03:21 PM
Tiger Rag's Avatar
There is a fuel grade teflon tape. It is kind of yellowish in color. I do know most systems say to not use it though. I know most of the fittings are brass and you should be able to get them not to leak, but sometimes that doesn't work. I'd just stay away from the orifice at all with tape, in other words keep the tape about 2 threads up the male pipe thread. Same goes for any brush on thread sealant.
Old Jun 7, 2006 | 08:09 PM
scottsjeeprolet's Avatar
I think that your problem might be that the fittings on the LP and filter housing are not NPT they are a straight thread. that's why the banjo fittings have washers.
I'm someone here will chim in with the correct type of thread.
NPF or BPT
Old Jun 8, 2006 | 06:31 AM
edy's Avatar
edy
the lealks are are taken care of i think i used pipe dope on the fittings the only thing i used n.p.t. on was the blue pump and the regulator.
Old Jun 8, 2006 | 08:27 AM
KITCHEN's Avatar
i'm sorry.. what is the blue pump and were do i get it? thaks
Old Jun 8, 2006 | 08:54 AM
Mike D's Avatar
Are you Jake? If so, how's the ECM working out for you?
The blue pump is a Holley Blue fuel pump, you can get them at advance auto.
Old Jun 18, 2006 | 07:25 PM
DMcPherson's Avatar
I will be installing a black pump shortly and have a couple questions for ya if you dont mind. what size are the stock fuel lines, and what did you wire to. I would like to run the pump on the same cycle as stock with the stock one in place. any info would be appreciated. thanks. Dan
Old Jun 18, 2006 | 08:28 PM
Mike D's Avatar
I used a relay to power the blue pump. I pulled power to trigger the relay from the positive wire going to the stock pump.. The stock fuel line is 5/16, 1/4 rubber hose will fit over the 5/16 just right, you can cut it up by the transfer case with a small tube cutter.
my 1 ton
28
Apr 28, 2009 11:02 PM
clowndodge01
Jan 20, 2008 01:00 PM
smokinstrokes99
16
Jul 2, 2007 03:36 PM
rockrunner
Mar 5, 2007 03:44 PM
texaspower19
Apr 28, 2006 05:39 PM
