Injectors too big??
Old Sep 19, 2006 | 12:29 PM
daysel's Avatar
Injectors too big??
I want to put some injectors on my 98 24v that's stock. Are 200hp injectors going to be too big, or should I go with some 150hp?
...All I plan on doing for this truck is a tuner besides the injectors.
Thanks,
Old Sep 19, 2006 | 12:39 PM
RowJ's Avatar
Your tranny won't play well with that much power.
A Smarty and a set of Mach 4's (150 hp) dynoed at 400 hp.... but your tranny won't hold that either... for very long!
I would much prefer an adjustable Box that could better control smoke and be turned down to appease your stock tranny.
RJ
Old Sep 19, 2006 | 12:52 PM
blackdiesel's Avatar
Registered
you will need gauges first ( if you don't already have them). Then like rj. said your tranny and your egt's won't like you at all, if you tow, you will want something you can turn down to keep you egt's in check.
Old Sep 19, 2006 | 12:55 PM
daysel's Avatar
Ahhh, the tranny.....
Well, whats a good VB and a TC?
Old Sep 19, 2006 | 05:03 PM
Charlie8301's Avatar
HTS is having a special right now on tc/valvebody combo
http://www.htstransmissions.com/Store.html
Randy
Old Sep 19, 2006 | 05:29 PM
redstreak's Avatar
Mach 1.6's would be a great injector for a little added power and some mileage increase. They're around a 90hp rating above stock.
Old Sep 19, 2006 | 06:39 PM
kelownadiesel's Avatar
youll never burn that much fuel with a stock turbo
Old Sep 19, 2006 | 10:28 PM
Ph4tty's Avatar
If you're refering to Bob you forgot to mention his hyrid turbo. Hohn is running that combo with a stock turbo but I don't think he's dyno'd.
Mechanos
Jan 22, 2009 11:25 AM
chopper9451
Apr 11, 2008 09:38 PM
5.9Excursion
Jul 25, 2007 09:42 PM
Ramdriver15
17
Jul 15, 2007 09:03 PM
O.T
Jun 7, 2007 11:55 AM
