Injectors!!
Old 01-17-2010, 10:17 PM
zmann's Avatar
Injectors!!
If i put 100 hp or 150 hp injectors in my 99, do i have to adjust timing or anything? Or can i just put them in and have fun?
Old 01-17-2010, 10:26 PM
1999blackcloud's Avatar
This has nothing to do with your post but do you have any tranny work done? I was wanting to put injectors in my truck but didnt know if the stock tranny would hold up. thanks
Old 01-17-2010, 10:41 PM
zmann's Avatar
I have just a bd valve body. Its holding up pretty good right now, but im adding more power so i might have to upgrade the tc.
Old 01-17-2010, 10:54 PM
Dinner's Avatar
You don't have to adjust your timing. Granted it would be beneficial to have a fueling/timing box but you don't need one in order to run those injectors. Also you're tranny may or may not last long depending on how you drive. But you will need to do something soon.
EDIT: Just saw that you have a power puck, I'm not sure if that adds timing or not?? But with that and bigger injectors your tranny wont last long unless you get an upgraded TC.
Old 01-17-2010, 10:55 PM
zmann's Avatar
does edge juice do timing?
Old 01-17-2010, 11:01 PM
8UPRACIN's Avatar
Yeah the Juice does fuel,boost and timing. thats what i am running
Old 01-17-2010, 11:05 PM
zmann's Avatar
alright. I just ordered one saturday, so ill have to save up again to get injectors. haha.
Old 01-17-2010, 11:11 PM
8UPRACIN's Avatar
Better start saving for tranny parts too!! After all the fun your gonna have testing the new chip I got a feeling the tranny is gonna be hurting!! My old clutch sure did
Old 01-17-2010, 11:15 PM
zmann's Avatar
Yea i better think about that one too. I'm trying to build it, its getting there, slowly but surely.
Old 01-17-2010, 11:32 PM
8UPRACIN's Avatar
I hear ya there. You'll like the Juice. Mine has been a 4 year project. My wife thinks its done but it'll never be done with all the new goodies coming out every year
Old 01-18-2010, 08:29 AM
zmann's Avatar
does the edge come with everything to hook up the gauges?
Old 01-18-2010, 09:26 AM
8UPRACIN's Avatar
yeah. Its got the EGT probe, fuel pressure sensor and hooks into the MAP sensor to get the boost pressure.Plus you can set it for tire height also which is kinda nice to have it up there on the display for when your cruising. Plus it will de-fuel and has alerts to let you know if something is wrong
Old 01-18-2010, 12:17 PM
The Guru
Mike Holmen's Avatar
You tow with the truck? You still running a stock torque converter and turbo? I think that you should be ok. You might be abit smokey, but it should still be drivable. The power puck is just a small power increase. Another upgrade would be to go to an edge comp box, juice and adredline aka tapping the pump. Being an earlier truck, you have a larger turbine housing on the turbo. I ran a HY-35, comp box and 90 injectors for 100000miles, along time ago. Towed and hauled heavy. You just have to watch the egt's when you tow.
Old 01-18-2010, 06:32 PM
zmann's Avatar
thats what i want more of...smoke. haha. But i only tow during hay season mostly. I'm trying to find an hx-35 or 40.
Old 01-18-2010, 06:36 PM
zmann's Avatar
Oh yea....where do i find an adapter for the airdog, to hook up the edge fp gauge? or is there somewhere i dont know about on the airdog to hook it up?
Quick Reply: Injectors!!
