Incorrect shocks
Old 12-16-2006, 07:41 PM
automeister3's Avatar
Incorrect shocks
Ok so I have ordered and rejected 4 seperate shocks all incorrect. The truck has air shocks on the front normal bushing on top large bushing on bottom. I wanna do away with the air shock however every shock I order has an eg1 bushing on the front lower mine has a large eg2 bushing please help!!!!
Old 12-16-2006, 08:41 PM
2stroke's Avatar
go into a shop, tell them what u want, and let them get em for u.
Old 12-16-2006, 08:51 PM
been there done that even went to a specialty suspension shop anything they look up is wrong. Is there anyone with a 93 w-250 if so can you look at your front lower shock mount and describe. Mine has solid probable 3/4 inch bolt going through mount and shock.
Old 12-17-2006, 09:26 AM
jogl's Avatar
On the lower end mine has a stud that looks to be about 1/2" (fine threads) going through the shock and about 3/4" (fine threads) going through the frame mount. Same on my '92.
JP.
Old 12-17-2006, 09:32 AM
JP.
Did yours come factory with air shocks? I believe mine are factory and I dont have a stud just a bolt. In the end I might have to change the lower shock mount however I would really like to know if this is original. My truck has alot of weird options.
Old 12-17-2006, 09:42 AM
jogl's Avatar
Now you are asking tough questions. The shocks look like normal shocks to me (there are no air lines coming out or anything).
The build sheet for this truck says "SFB Front Heavy Duty Shock Absorbers". However, I just acquired the truck so I don't know if those are original shocks or not.
JP.
pet05
11-02-2006 11:10 PM
walexa
02-22-2006 07:26 AM
GarettD
09-17-2004 11:57 AM
Lary Ellis (Top)
11-28-2002 07:27 PM
Quick Reply: Incorrect shocks
