I'll try it one more time
Old Nov 18, 2007 | 11:48 AM
superuke's Avatar
Hello, I didn't get a response the last time I posted, so I'll try again.. When I start in drive, the trans. chatters. Once it shifts into 2nd & 3rd it works fine. it will do it empty, but more noticeable when I got my 5th wheel RV trailer hooked on..
Old Nov 18, 2007 | 03:34 PM
kas83's Avatar
Torque converter.
Old Nov 18, 2007 | 05:22 PM
Dr. Evil's Avatar
Originally Posted by kas83
Torque converter.
Thats kind of what I was thinking
Old Nov 18, 2007 | 05:54 PM
D-Roc's Avatar
Hey Doc, how's things?
Old Nov 18, 2007 | 05:59 PM
Dr. Evil's Avatar
Good...
you missed the dyno day Derek...
Old Nov 18, 2007 | 07:10 PM
superuke's Avatar
Thanks all, I guess time to go hunting for a TC..
Old Nov 18, 2007 | 09:10 PM
oldblues's Avatar
hi
how would this be a t q prob when the convertor clutch is not engaged ?
maby just a trany mount / motor mount ?
or a bad sensor / speed / govenor ?
low line psi ?
if the vertor were bad it would not stop chattering?
help me understand ?
Old Nov 19, 2007 | 07:47 AM
superuke's Avatar
Will do some checking today.. I'm in south Texas right now, & problem here is there's a transmission shop every mile, & I'll have to try & find one that know what they're doing.. Are there bands in these trannys that could be or need to be adjusted..??
Old Nov 19, 2007 | 08:17 AM
berner's Avatar
I'm doubting the TC issue too since it doesn't chatter in 3rd gear. John, keep us posted as to what you find out. I don't recall seeing this problem posted before.
Old Nov 19, 2007 | 09:24 AM
superuke's Avatar
I'll scout the phone book, & hit a couple shops, & see if I can get any opinions from a couple of shops..
John
Old Nov 19, 2007 | 11:57 AM
superuke's Avatar
Well I just got back from 2 shops, both different diagnosis.. First one said the chatter is caused by slipping clutches, & needs work done.. The second one said the trans oil doesn't smell at all, but the oil should be changed.. But the chatter is caused by 2 bad U-joints (rear).. I did notice a loud clank when shifting from Park or Drive to Reverse.. Funny I did take it to the Dodge dealer in Canada about the clunk, & they said that a certain amount of slop is quite normal.. Made an appointment for tomorrow morning to change the U-joints, & will let you know if that helps the problem, or eliminates it.. The second shop said that there may be some slippage in the tranny, but have to eliminate the U-joints first, & then see.
Old Nov 19, 2007 | 12:19 PM
CarlJensen's Avatar
Could be U joint or the drive shaft support bearing. Also rear end. I would do more checking before opening wallet to a tranny shop.
Old Nov 19, 2007 | 12:26 PM
J OOPS's Avatar
Could be the bands need adjusting. One of the bands can be adjusted by yourself. The adjustment screw is on the outside of the tranny. I can't rember what the adjusment is supposed to be but it is in DTR just need to do a search for it.
Old Nov 19, 2007 | 12:40 PM
superuke's Avatar
No luck in searching yet.. does it tell you how much to adjust it? I was under the impression that only clutches were in the trans.
Old Nov 19, 2007 | 12:51 PM
Dr. Evil's Avatar
Adjusting bands...look here: http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Steal (maybe borrow) a Texas license plate and put it on your truck so you dont get raked over the coals at a tranny shop.
