If I want to comfortably tow 18000 lbs what do I need?
Good day men,
I am a contractor with a 2003 HO 2500 QC with 48RE and 3:73 gears. I have a superlift 6" with bilsteins as well as toyo 37" 13.5 " M/Ts as well as my Juice on 1 and my Predator on Performance. I have the AEM brute force and MBRP cool duals.
Basically I want to be able to comfortably haul my 2 S250 skidsteers (8K each) on my trailtek industrial trailer (5.5k) without too much trouble. That's not a gooseneck either.
Upgrading to a 2008 Ford F450 is not an option guys. What do I need to be safe? (this is in hot sunny Barbados btw)
Thanks,
Gerren
Thanks,
Gerren
To be safe haul 1 at a time. Especially without a goose. I pulled a s250 and a catepillar skidsteer that was bigger than the 250 on a goose, mines a duallie, but lets say I won't do it again not without a bigger truck.
Gerren, In Barbados eh!...you need a diesel truck consultant to take a look at the situation....luckily I'm available....I'll pm where to send the plane ticket.
The truck will tow it fine....I assume it is a little beavertail flatdeck with good brakes...A set of air bags will keep the truck axle from bottoming out. Does it use a pindle hitch....What are the speed limits you operate with. With those tires it would be great if you had a 4x4 so that you had 4 LO. If you don't use 4wd you could disconnect the front shaft so that you could run in 4 LO. I've towed much more than that farther and faster but the roads are probably narrower and more congested. Ideally, you need a 4.56 gear ratio at least. Is your truck 4x4...you have tons of power but mechanically you are lacking and your factory hitch or even a class 5 is useless for that much weight....A gooseneck would make this easy. ks
Well I pull right around 20k, but I have a dually with bags and tires and gross at 10k a piece along with a ton of engine mods and dd clutch. I have absolutly no problem at all with this weight.
But he has to stop it too, and having a 2500 single wheel with 37" tires and lift on a bumper hitch???????? not safe for him or the people around it. He better have insurance for the load.
373 gears pushing 37 inch tires, gonna need a friend with a tranny shop too..... 410's would help a bit getting it going but man o man stopping the rig, yikes. where you are located makes a big difference as well, are ya in an area flat as a pancake, or billygoatsville?
8K+8K+5.5K+ truck, you're getting close to 30K. I think you need a larger truck. Sure you can move it, but how about stopping. I have a C10 Chevy for a service truck that at times I have to pull start loaded gasoline tanker, 80K+ at times. Being able to move extreem weight dosen't mean you can control it.
