If I want to comfortably tow 18000 lbs what do I need?
Good day men,
I am a contractor with a 2003 HO 2500 QC with 48RE and 3:73 gears. I have a superlift 6" with bilsteins as well as toyo 37" 13.5 " M/Ts as well as my Juice on 1 and my Predator on Performance. I have the AEM brute force and MBRP cool duals. Basically I want to be able to comfortably haul my 2 S250 skidsteers (8K each) on my trailtek industrial trailer (5.5k) without too much trouble. That's not a gooseneck either. Upgrading to a 2008 Ford F450 is not an option guys. What do I need to be safe? (this is in hot sunny Barbados btw) Thanks, Gerren |
Safe for the truck or safe for you?
Both preferrably [duhhh]
A medium duty truck. There is no way a pickup truck towing 8k + 8k + 5.5k = 21.5 K can be towed safely with a pintle hitch![nonono]
Originally Posted by strictlydiesel
(Post 1431946)
To be safe haul 1 at a time. Especially without a goose. I pulled a s250 and a catepillar skidsteer that was bigger than the 250 on a goose, mines a duallie, but lets say I won't do it again not without a bigger truck.
Gerren, In Barbados eh!...you need a diesel truck consultant to take a look at the situation....luckily I'm available....I'll pm where to send the plane ticket.[coffee]
The truck will tow it fine....I assume it is a little beavertail flatdeck with good brakes...A set of air bags will keep the truck axle from bottoming out. Does it use a pindle hitch....What are the speed limits you operate with. With those tires it would be great if you had a 4x4 so that you had 4 LO. If you don't use 4wd you could disconnect the front shaft so that you could run in 4 LO. I've towed much more than that farther and faster but the roads are probably narrower and more congested. Ideally, you need a 4.56 gear ratio at least. Is your truck 4x4...you have tons of power but mechanically you are lacking and your factory hitch or even a class 5 is useless for that much weight....A gooseneck would make this easy. ks |
I second the med. duty truck idea. Or go buy a used Class 8 rig - single rear axle - and slap a hitch on the back of it if you're going pintle.
Originally Posted by truckjunkie
(Post 1431966)
But he has to stop it too, and having a 2500 single wheel with 37" tires and lift on a bumper hitch???????? not safe for him or the people around it. He better have insurance for the load.
Originally Posted by rowlrag
(Post 1431985)
But he has to stop it too.....
Ok [duhhh] Trailer brakes are to help, no stop everything.
Your going to need a bigger truck.
373 gears pushing 37 inch tires, gonna need a friend with a tranny shop too..... 410's would help a bit getting it going but man o man stopping the rig, yikes. where you are located makes a big difference as well, are ya in an area flat as a pancake, or billygoatsville?
8K+8K+5.5K+ truck, you're getting close to 30K. I think you need a larger truck. Sure you can move it, but how about stopping. I have a C10 Chevy for a service truck that at times I have to pull start loaded gasoline tanker, 80K+ at times. Being able to move extreem weight dosen't mean you can control it.
