hydraulics issue ?
Old Apr 9, 2007 | 12:44 PM
tsdiesel's Avatar
hydraulics issue ?
I've read the post(s) in this group on clutch / hydraulics none seem to point to my issue.
I have an 02 2500HD, 5.9 5 speed, 2 weeks ago I had the clutch replaced as it was bad slipping and chattering real bad under load and from normal start. Visual inspection showed the clutch was worn (work was done by a local shop).
Before taking the truck the clutch pedal acted strange, and still does on occasion. Basically when one pushes the clutch pedal to the floor if feels normal meaning pressure is there shifts ok ....., when releasing the clutch (this is the strange part) sometimes the pedal looses pressure, meaning you can not feel the pressure against the clutch as the pedal returns to it's normal position eventually you can feel the pressure catch up with the pedal. When this happens there is chattering as the truck begins to move.
Could this be hydraulics or the clutch job not done right ? Once engaged clutch seems to work fine.
Old Apr 9, 2007 | 02:01 PM
Barry St John's Avatar
Take it back to where you had the work done and let them take a look at it. It seems to me that there may be something wrong with the pressure plate!? Wild guess but the symptoms you describe need to be addressed and the shop is responsable for their installation.
Old Apr 9, 2007 | 02:15 PM
tsdiesel's Avatar
thanks, eventually I will take it back to them. But i wanted to get some feedback, before I take it back. So I can better understand the issue as I talk with the shop.
Old Apr 9, 2007 | 02:32 PM
RAFTEN's Avatar
ts, did the shop replace the master/slave? I am guessing they did not and I am having sort of the same problem. Please post what you find out from the shop.
Old May 19, 2007 | 12:18 AM
tsdiesel's Avatar
Well finally got the master /slave replaced with a SB unit clutch pedal problems solved.
Just in time to take the 5th wheel out for sure
6speedcowboy
Aug 25, 2006 07:51 AM
GO 4LO
May 17, 2006 07:57 PM
hotmopr
May 15, 2006 02:52 PM
Neal Cassady
Nov 19, 2005 02:33 PM
Bart Timothy
Jul 20, 2005 01:36 AM
