HX35 worth the upgrade?
Old Oct 26, 2005 | 02:38 PM
67HotRod's Avatar
HX UPGRADE?
I have access to a new, out of the box, HX35. Was wondering if its worth upgrading my little HY35? I know an after market unit would be the better way to go, if I had the money.
My Fuel tank swallowed my wallet!
67HotRod
Old Oct 26, 2005 | 02:55 PM
RowJ's Avatar
Depends on the price, I would think!
But your HY-35 has no right being under the same hood as an Edge Comp...unless your running it as an EZ. There is a big difference between a 9 cm2 turbine housing and a 12 cm2 housing...assuming that's what the HX-35 has. It will help you out a lot, and probably take you to 400 hp, with only minor egt problems.
RJ
Old Oct 26, 2005 | 03:34 PM
67HotRod's Avatar
I'm still running the comp is EZ mode, Still on the original IP and Still have a 3" straight exhaust. The turbo is available now...
67HotRod
Old Oct 26, 2005 | 05:33 PM
BigBlue's Avatar
If you can get it cheap, then go for it. After upgrading mine from the HY to the KSB-1 and feeling the difference in the top end, I firmly believe that the HY is to little for anything over stock.
Old Oct 26, 2005 | 07:09 PM
Marine's Avatar
Veteran: Marine Corp
I was going to wait for a Dodgzilla, but if you want to sell the HX, I might take it off your hands.
Old Oct 27, 2005 | 12:07 PM
67HotRod's Avatar
My neighbor has the HX35, haven't talked price yet. He was thinking about a twin setup...
Old Oct 28, 2005 | 03:15 PM
j-dubya's Avatar
im kind of new to this stuff. what should i expect from changing my hy30 (comes with the auto correct?) and a hx35 12cm from a manual? i want to go to a better one of course, but money is a big issue right now with one last competition coming up.
thanks,
jeremy
Old Oct 28, 2005 | 06:06 PM
BigBlue's Avatar
If your stock, then don't bother switching. If you've got a fueling box of any sort, then switch. After seeing the difference in top end between a KSB-1 and an HY-35, I'm a firm believer now that the HY35 is to small for anything over stock and even then I question if it's to small.
Old Oct 28, 2005 | 07:51 PM
j-dubya's Avatar
after this last comp and i pay some bills, im adding a few goodies.
Dodgin&Rammin
Jan 9, 2010 01:10 AM
sshort
Feb 26, 2009 10:32 PM
AlanF
Jan 17, 2008 08:07 AM
rbrettctd
Apr 18, 2007 10:37 PM
bwat4
Dec 15, 2004 05:08 PM
