Hunting diagram?
Old 09-11-2011, 11:19 AM
daddy mopar's Avatar
Hunting diagram?
I like most of the 2nd generation owners battle the frustrating 4th gear hunt. A fellow member of the club emailed me this diagram. I am hesitant to start cutting wires to the ECM and PCM. I am hoping one of you have the expertise, the experience, or knowledge to tell me if this diagram is good.
Daddy Mopar
File Type: pdf
Last edited by daddy mopar; 09-11-2011 at 11:22 AM. Reason: Another website is advertised.
Old 09-11-2011, 11:27 AM
Clunk's Avatar
Here's ATS's procedure full size,
http://www.atsdiesel.com/additionali...02)%20v1.0.pdf
Ooops, didn't see the .pdf
Old 09-11-2011, 04:27 PM
olddodgetrucks's Avatar
did mine 3yrs ago,no more hunting,solder connections
Old 09-12-2011, 12:35 AM
I just want to make sure this is a legit diagram. I can just see the dollar signs rolling if something isnt right.
Have there been any repercussions olddodgetrucks? Any codes?
Old 09-12-2011, 07:58 AM
high bid's Avatar
You might want to start w/cleaning all the grounds you can find first as the least cost option. This is the major cause of trans hunting.
Old 09-12-2011, 12:31 PM
1/2 hr no cost and rewire works
Old 09-12-2011, 06:58 PM
Ive checked my grounds, greased them, tightened them until i had to replace cables, checked other grounds, applied the wire insulator, and still it hunts. Basically everything i can find to do, ive done to stop the hunt.
I am just worried about cutting a wire when i dont know exactly what that wire does.
Old 09-14-2011, 07:33 AM
floodlight's Avatar
This is an electrical problem. The APPS is generating too much noise. Get the noise filter from http://www.dieselperformance.com/ind...uct/index/185P
It worked for me.
Old 09-14-2011, 08:08 PM
whiskers's Avatar
I did all that stuff and had to put on the Timbo APPS to get running smooth and quit hunting.
Old 09-15-2011, 10:40 AM
high bid's Avatar
Corrison is not just a one time cleaning. Be certain to clean the two point infront below the driver batt, one next to the pass batt and the two ground points by the ECM.
Old 09-15-2011, 05:17 PM
dkenny's Avatar
that's about what I did to solve my problem.
I just added the ground wire from the battery to the APPS ground near the connector..
also check the tranny fluid level..
-dkenny
Lary Ellis (Top)
09-25-2003 04:38 PM
Redleg
11-14-2002 07:01 AM
wick
10-31-2002 05:02 PM
Palmetto_kid
10-10-2002 08:32 AM
Quick Reply: Hunting diagram?
