What HP can you go without FASS or airdog?
Old 01-02-2008, 09:45 PM
sallyman1's Avatar
If you run a edge juice on levels 1-3 will you need a FASS? i know it sure wont hurt to have 1 but will u need 1?
Old 01-02-2008, 10:32 PM
omaharam's Avatar
Don't even need it on level 5 until you get the HOT upgrade.
Old 01-02-2008, 10:39 PM
sallyman1's Avatar
if i run edge juice attitude on levels 1-5 and keep my stock turbo I wont need FASS or GLacier you are saying? I will be running ****** whistler and aero 4040xl with cat and muffler delete as well. so my EGTS shouldnt be that high. Will I kill my stock fuel pump?
Anyone ever heard of a BD auxilary Lift pump for vp44 and cp3s? Its $318
Old 01-02-2008, 10:43 PM
Hvytrkmech's Avatar
I run my fuel pressure right down to zero then negative with just my Quad xzt, that is with a 2 micron filter installed just before the CP3, so I ordered an Air Dog 100. You might be ok without the added restriction of an extra filter.
Tim
RamWheelsBy4's Avatar
I agree as long as your stock lift pump is functioning normal you can run a standard Juice/Attitude even on level 5 without any problems.
Old 01-02-2008, 10:44 PM
Spooler's Avatar
If you haven't had the in tank LP upgrade done the stock LP on the back of the fuel filter canister will kill itself. It dosen't need much help....
Old 01-02-2008, 10:56 PM
omaharam's Avatar
Tim
You have a bad pump or need to change a filter. A 65hp box shouldn't even come close to pulling down to 0psi.
Old 01-02-2008, 11:03 PM
Festus's Avatar
My pump is good and changed my filter.....twice. I still can easily pull my fuel pressure to zero - quad tow module, intake, and exhaust mods only.
Old 01-02-2008, 11:08 PM
Hvytrkmech's Avatar
I'm thinking bad pump, lack of max boost pressure (20-22 psi max), 1500* egt at wot, thats why I went for the Air Dog, also truck just serviced, both fuel filters, air and oil changed.
Tim
Old 01-02-2008, 11:20 PM
Seeder's Avatar
What is strange with the commander is that you can go in and adjust your fuel pressure so it will read higher than it is. Mine read 8 psi at idle and with the 65 hp box I can pull it down to 2 PSI. I went in and adjusted the setting and now it reads 10-11 lbs at idle and at wot it drops down to 4-5 psi. The drop is the same but the peace of mine is better
I sometimes question the accuracy of the fuel pressure sensor, who really knows how accurate it is. My dealer told me that he checked my LP PSI when diagnosing a starting issue and he said that it was plenty strong and would handle some HP increase. He is a nice guy but that doesn't mean that he is honest.
-Seeder
Old 01-03-2008, 12:26 AM
trik396's Avatar
Back when I only had an XZT, I'd pull it down to zero. Clean filter also. Went Walbro right after that. 20psi always, or whatever I set my regulator for... Gotta love the consistency of the wonderful stock fuel pumps...
Old 01-03-2008, 12:27 AM
gus's 03's Avatar
we data logged mine and i see no loss of rail presure with my truck. beta software and all... still running stock lift pump and 2mic filters. thats level 9 on the smarty, and over 50psi boost pushing the fuel map...
Old 01-03-2008, 05:52 AM
sallyman1's Avatar
how many mic filter is the stock filter and filter housing from dodge for our 3rd gen diesels?
Old 01-03-2008, 06:05 AM
trik396's Avatar
They were 10mic then they changed them to 7mic because of problems. Still isn't enough. You cannot have too clean of fuel. PERIOD...
Tractor Truck
01-20-2011 01:56 AM
JaimeG
03-26-2009 06:58 AM
woodrep
02-22-2009 11:19 AM
kdbvulcan
20
12-06-2008 04:34 PM
Spooler
12-27-2007 11:19 PM
Quick Reply: What HP can you go without FASS or airdog?
