Horse power ?
Old May 23, 2008 | 09:26 AM
maxx250's Avatar
Horse power ?
Who can tell me what the difference is in HP between a 91 turbo non intercooled and a 93 1st gen.
Old May 23, 2008 | 10:13 AM
C/PRD/'s Avatar
I thought they were both 160HP from the factory.
Old May 23, 2008 | 05:47 PM
They are both rated at 160 HP, but most stock non-IC trucks will run rings around most stock intercooled trucks.
Old May 23, 2008 | 08:00 PM
bradshaw106's Avatar
is that because of the size of the injectors?
Old May 23, 2008 | 08:03 PM
G1625S's Avatar
Yup. They also tend to spool faster due to the lack of IC plumbing.
Old May 23, 2008 | 08:28 PM
big stinky's Avatar
Im sure the 18cm compared to the 21cm turbine housing would have something to do with that too... More air to pack plus huge turbine housing = .
Old May 24, 2008 | 06:14 AM
powerrammaster's Avatar
Ive got a 91 non I/C and a 92 with I/C and Banks 14 cm and that little 91 WILL run circles around the cooled truck. The 91 is untouched and the 92 I am constantly working on to get it to where the 91 is. The 91 spools up fast.
Old May 24, 2008 | 11:43 PM
JQmile's Avatar
My "stock" non-intercooled truck ('89) rated at 160 flywheel hp made 170rwhp when I bought it with 200K on it. The last "stock" 93 I saw tested made about 130rwhp. Ouch. non i/c trucks have about 20% larger injectors.
Old May 25, 2008 | 01:27 AM
whereswaldo250's Avatar
I have been looking on and off to find a cheap non i/c truck but they can be hard to come by.
Old May 25, 2008 | 08:54 AM
rebal's Avatar
We took a non/ic ve pump( stock )and put it on a 92 and it runs way differant the 92 pump was tweeked. the new pump rips off the line and builds boost way faster . I dont know what is differant in the pumps or the setting of them but there is defenitly something going on + tweeking the new pump is real sensitive and EGTs go way up faster now.
the new pump came off off an after cooled 12v engine used on a pump that the farm labors unhoocked the safety shut down system. and then ran the cummins out of oil.while it was running 24/7
Big Joe
Sep 16, 2005 03:36 PM
cummins dsl
Feb 16, 2005 12:34 PM
geer
Jul 11, 2004 09:36 AM
javamann
May 4, 2004 10:23 AM
boehunter49
Nov 24, 2002 09:40 PM
