High engine idle in winter months
Old Jan 19, 2008 | 09:22 AM
jj3500's Avatar
I asked this question last winter, no responses.
In the winter months, driving truck on highway for 60 mins., pull on off ramp, sitting at light. My idle will be close to 1000 rpms. If i shut it down then start it back up, the idle will be normal. But this happens like clock work...only in cold weather. Truck is so loud idling so high at a light. Is it suppose to be that way? I haven't heard of other members saying this.
Anyone?
Old Jan 19, 2008 | 10:32 PM
TexMexCowboy's Avatar
You know i had the same question I hope somebody answer's this question.
Old Jan 25, 2008 | 03:16 PM
farmer dave's Avatar
Have you tried tapping the pedel to see if it goes back to normal idle? If it doesn't then the high idle isn't the problem. It shouldn't be the high idle if you have be driving for 60 mins. because the engine would be warm.
Old Jan 25, 2008 | 03:52 PM
caleb_s's Avatar
Yeah, I would try tapping the pedal...but I agree the high idle should only come on if you truck is really really cold. I know mine only comes on in the morning when I park outside but after I drive for a while it no longer comes on.
Old Jan 25, 2008 | 09:08 PM
stickler's Avatar
If it's similar to the new ones, the high idle is activated by manifold temperature. What you describe is VERY common in cold weather. Running down the highway, you build some heat, but slow down and you engine temp plummets like a 16 ton weight. Watch your temp gauge next time it does it, I bet you'll see it's dropped way down. It should go off as soon as you touch the brake. You got to keep in mind that the cooling system on these things is designed for heavy pulling in hot weather. It's absolute overkill in winter weather. I've actually had mine cool off enough for the grid heater to come back on, in the same situation you describe.
Old Jan 25, 2008 | 09:35 PM
jj3500's Avatar
the idle does not come down if I tap brake. I'm at a traffic light with my foot Standing on the brake. Idle does not change. if I tap it or stand on it. ??
Old Jan 25, 2008 | 11:26 PM
ytodd's Avatar
wrong pedal to tap
tanderson2002us
Nov 17, 2010 09:36 PM
kicker210
Dec 2, 2009 08:23 AM
jmccart
Jun 12, 2007 02:12 PM
Jannetty Racing
Jan 11, 2006 07:11 PM
jj3500
Dec 25, 2005 11:02 PM
