HEADLIGHTS out !
Old Nov 29, 2009 | 07:38 PM
bluepuller's Avatar
HEADLIGHTS out !
Help my Dim headlights will not work. I have brights but driving around with nuthing but that well it doesnt make friends .
When I hold the dimmer switch at the half way point i have both bright and dim lights on at the same time but if i just try to use regular headlights there is nothing! thanks in advance for your replys
Old Nov 29, 2009 | 08:14 PM
mishkaya's Avatar
It's usually one of two things: either a bad ground to the headlights, or a bad multifunction switch. (Could possibly be a fuse I suppose, but I would assume you have already checked that).
Old Nov 29, 2009 | 09:20 PM
scottsjeeprolet's Avatar
I had the same problem. It was the purple wire in the column under the cover. Only the high beams worked. The wire comes loose, just tightened the connector and a little RTV to help hold it.
Old Nov 29, 2009 | 09:55 PM
bluepuller's Avatar
Thanks for the advice ! I will check these things in the morning !
Old Nov 30, 2009 | 08:04 AM
smokeyram's Avatar
ill just throw this out there, since i had the same issue, yet it was not the loose wire or multi switch. the harness for my western unimount had gone bad. after 2 days of looking for a short or bad ground, i just decided to unplug the jumpers the western harness uses and plug the headlights into the factory harness. viola, lights came back on.
Naturally because i changed the light swtich, the multi funtion switch and made sure all wires under the dash were tight, i cant say which it was for sure. but unplugging the western harness did it in the end.
Old Dec 2, 2009 | 03:20 PM
Dinner's Avatar
Whenever my low beams go out (usually when I want to switch from high to low). I just give it a quick/hard snap to high then back to low again. Usually that does it as I can usually hear/feel the difference in the switch. Eventually I'll buy a new switch,lol. I have DRL though so even if my low beams don't work I can still see and not blind people.
slayerfish
Sep 12, 2007 09:51 AM
Dan MAYOH
Nov 25, 2005 09:44 PM
Festus
May 23, 2005 06:28 PM
mr T
Nov 16, 2004 07:33 AM
