headlight issues
Old Nov 26, 2006 | 08:58 PM
TRCM's Avatar
headlight issues
I've noticed lately, that sometimes the headlights seem to dim for a split second, and then go back. Not even long enough to see it on the ammeter.
Outside air temp has no effect, nor does vehicle speed. the dimming isn't consistent either (as far as time between dimming).
Any ideas ???
Old Nov 26, 2006 | 09:02 PM
TIMMY22's Avatar
just after startup?
heater grids cycling..
totally normal.
Old Nov 26, 2006 | 09:54 PM
TRCM's Avatar
no, any time...even after driving for many hours.
the dimming is no where near as noticeable as the heater grids.
Old Nov 26, 2006 | 10:11 PM
merrillr4's Avatar
You might have weak batteries or a alternator problem? I had a 2000 Jeep and it did the same thing, in the end it was a problem from a weak battery!!
Old Nov 26, 2006 | 10:19 PM
bentwings's Avatar
For what its worth:
Mine did it last night and tonight again and about 2 hours ago the left headlite burned out.
Old Nov 27, 2006 | 08:06 AM
mts-driver's Avatar
mine is doing the same thing right now daytime lights acted up drivers side went out but when I turn the switch on they both come on ... now that always does not work I have to cycle hi/low beam to clear it up but the dimming is still there from time to time I suspect something to do with relay's cant play with it now -23'C outside ( windchill -32'C )
Old Nov 27, 2006 | 10:00 AM
infidel's Avatar
If you don't use your brights much it could be the multi-funtion switch (turn signal) is dirty causing a poor contact. Spray electronic cleaner at the base of the lever while working the dim/bright and left right turn function back and forth.
Old Nov 29, 2006 | 09:34 PM
TRCM's Avatar
Well, infidel, as usual, you may have hit on the issue.
My multi function switch is acting up and I plan on replacing it soon. it doesn't always 'park' the wipers.
it's been doing it for months now, but I only drive it once or twice a month (too long for daily driving & parking and too long, wide, and new for hunting with).
Have to see what happens when I replace the switch
Old Nov 29, 2006 | 10:16 PM
Lil Dog's Avatar
Its the DRL module takin a dump on you.. Pull the plug on it and all will be well once again. You can jumper around it to get your highbeam indicator to work after that. I haven't seen the need to spend the $125 to get a new module.
Old Nov 30, 2006 | 11:44 AM
TRCM's Avatar
my truck does not have a daytime running lights........or at least not that I know of.
oops...now I see yer talking to someone else
mtdoragary
Nov 7, 2013 08:31 AM
archer39
Aug 19, 2010 07:33 PM
banks twinram
Jul 23, 2009 09:39 PM
TRCM
18
Mar 26, 2007 01:31 AM
jlipskoc
Oct 24, 2005 01:16 PM
