head light switch
Old 11-10-2003, 06:28 AM
Pureliving's Avatar
head light switch
My 95 CTD switch just quit (burned) on me. I was told it very common problem on dodge truck. Anyone out there have similar problem?
Old 11-10-2003, 12:45 PM
Partsman's Avatar
Re:head light switch
Yea, 97 toasted the headlight terminal completely out of the harness.
Old 11-10-2003, 12:46 PM
Smokee's Avatar
there is a recall on the headlight switch.
Old 11-11-2003, 05:39 PM
Cummnzpowr's Avatar
The switch recall is like only on the 95-97 3500 models only, i tried getting it taken care of under recall, but they declined. Did you smell the burning wires in cab ? i did, and saw smoke too..i am running aftermarket blue headlights though, i wonder if i change them out it won't burn up the switch?>
Old 11-11-2003, 06:22 PM
Smokee's Avatar
I installed a relay on my switch before the recall, and it still burned out. I finally figured out...after the third switch, that the problem was that if I ran for a long period with the dash lights dimmed, the rheostat would heat up and fry the two forward connectors on the switch.
I now carry the dealer replacement switch as a spare, but I have had no trouble for a couple of years as long as I do not run with the dash lights dimmed.
george
Old 11-12-2003, 06:35 AM
Pureliving's Avatar
I replaced the switch, noticed the female connector melted. Can't figure why. I am not using aftermarket headlights. The new switch became warmer in 30 sec when headlight were turned on .
Pureliving
Old 11-12-2003, 08:53 AM
Cummnzpowr's Avatar
all i can guess is dodge junk :...thank goodness we have a good engine
smokeyram
08-21-2009 06:19 PM
redramnc
03-28-2005 06:58 AM
INJECTOR JACK
01-21-2005 09:43 AM
hekroh
11-02-2003 01:30 AM
frank
10-31-2003 08:10 PM
Quick Reply: head light switch
