have ????
Old Dec 1, 2002 | 08:37 PM
dsl-nut's Avatar
Muted User
have ????
Hi I have 95 cummins I removed the fuel plate and ground it all the way back put a slight half moon in it and smoothed it off real good with steel wool ,moved the afc housing all the way forward ,ajusted the star wheel ,I now have way more power then I did but cant hit 1300 degrees on the egt gauge is that normal ? also is that like running a 0 plate ?if I removed the plate would it be any difference than it it now?<br><br><br>Also my engine stumbles at 1000 to 1300 rpm is thier anything i can do to fix it? Ilive in Springfield MO and cant find any one to time my trck how hard is this to do does anyone know of someone in my aria that could time it?<br><br>thanks all
Old Dec 1, 2002 | 09:11 PM
SmokinDodge12V's Avatar
Re:have ????
Does your clutch slip now if stock? 1300 degrees pre turbo is ok all day long but post turbo is not good for long periods of time.
Old Dec 1, 2002 | 10:38 PM
RCW's Avatar
RCW
Re:have ????
I am assuming you ground off the &quot;tit&quot; that is the rack follower spring lever stop to get the follower to go all the way to the bottom of your new cam profile? If not, all you have accomplished is move your stock fuel plate forward.<br><br>When you look at the stock plate there is a foot, a little ramp that probably goes backwards on your truck, a stop about 5/16&quot; up the plate, and then a drop into the back of the plate. The stop must be removed, the little slight ramp angled about 38 degrees for 5/16&quot; toward the front of the plate and into the crecent. The follower should drop into the &quot;crecent&quot; at 7/8 throttle and above.<br><br>You can check the action by watching through one of the inspection ports while you work the linkage by hand. The AFC must be removed or pulled forward all the way while you test or it will stop the follower from moving forward.<br><br>A zero plate has a stabilizer to keep the rack from slamming and the follower from bouncing around, and that is about all. <br><br>Do not remove the cam plate, you can damage your pump by letting the rack slam against the control surfaces, and also cause it to bind and perhaps give you a ride of your life! <br><br>You did do all the correct things with the AFC.<br><br>Check the links on this site and look for a speciality shop in your area. There are some chain performance shops, but they generally like to get you to &quot;grab your ankles&quot; for payment - too steep for me (and I started a chain of those pirates and sold them)! <br><br>If you make good friends with the Cummins shop folks, you can sometimes get one of them to time your truck the way you want, but do not expect them to warrant that work. Sometimes it works to take the license plates off and put it on a trailer and tow it in to the Cummins Service Center as an offroad vehicle. Otherwise, they will set timing to the CPL specs, and can end up without a job if they do otherwise to a highway legal vehicle and get caught at it.<br>
Old Dec 2, 2002 | 10:43 PM
dsl-nut's Avatar
Muted User
Re:have ????
My engine just started to tick real bad too im thinking it might be the valves anybody have any idias?<br>
Road Traveler
81
Nov 13, 2009 07:04 AM
Mark Thomas
Apr 30, 2006 08:20 AM
Intercooler
Jun 4, 2005 07:48 PM
routerguy99
17
Aug 11, 2003 12:21 PM
Nuttymopar
Apr 25, 2003 02:17 AM
