Have question about ECM and the OEM #
Old Oct 6, 2007 | 08:09 PM
CTD2001's Avatar
Well i finally figured out what was wrong with the 93 that i got, Bad ECM. I swapped the one in the truck with a know good working one, and sure enough, i got charging back, AC back and OD back. So now i am searching for a new or reman ECM but the sites that i look at have a few different options for a 93 ecm with an auto trans. Each one has a different OEM #. What is this OEM # and where can i find the OEM number so i get the right one, Thanks
Old Oct 6, 2007 | 08:53 PM
BC847's Avatar
1st Generation Admin
Single Board Engine Controllers (Power Control Module)
P/N 5602 6858 1993, Man. Trans., w/o RFI
P/N 5602 6859 1993, Man. Trans., RFI
P/N 5602 6860 1993, Auto. Trans., w/o RFI
P/N 5602 6861 1993, Auto. Trans., RFI
I don't know what "RFI" is.
Hope this helps.
- > The part numbers may have been superseded.
Old Oct 6, 2007 | 09:00 PM
KB440's Avatar
Look for the part number on the back. It's under the clear epoxy printed on the board.
Old Oct 6, 2007 | 09:42 PM
rustbucket's Avatar
I just put a ecu on my 93,I got it on the web from a place called ecu direct.I was very happy with it,it is a rebuilt,but looks brand new,inside and out. They way it looks,they must replace every thing.I had one froma place called cardones,it never worked right,and I sent it back,and they gave me another one it lasted about six months.They had a lower price,I guess you get what you pay for
Old Oct 7, 2007 | 08:42 AM
CTD2001's Avatar
thanks for the help, i will have to look and see what the oem number is, should be on the ECM itself right? Thanks
Old Oct 7, 2007 | 09:05 AM
KB440's Avatar
Yes it is, on the backside.
Old Oct 8, 2007 | 03:12 PM
CTD2001's Avatar
I found the OEM number, it is B56029103, does this number look right, i have not been able to find a 9103, only a 9102. It was under the case, under the appoxy lower right hand side if you have the plug for the wiring harness facing you. Thanks
Old Oct 8, 2007 | 08:33 PM
CTD2001's Avatar
anyone got any suggestions, thanks
Old Oct 8, 2007 | 09:16 PM
TOMTOM's Avatar
MY auto ecm is a 56029103 and my m/t is 56029101. a m/t ecm will not give you o/d on a a/t. hope this helps there may be many more # than we have.
Just looked on my truck and it has the 56026860, LOL!!!
TOMMY
Old Oct 8, 2007 | 10:11 PM
KB440's Avatar
Part number 56029103 was superceded by part number 4746568.
Old Dec 17, 2014 | 03:54 PM
james1's Avatar
Radio Frequency Interference:
TRNW Store: A618 / 47RE RFI Noise Filters
ratat98
Sep 18, 2016 07:34 PM
SKATERHAULER
Oct 2, 2013 06:34 AM
Shaun Cockran
May 8, 2012 05:52 PM
BAJA MAN
Nov 21, 2006 05:49 PM
Ohio Joe
Jul 12, 2004 12:13 PM
