Hard start in morning
Old 02-02-2007, 08:53 PM
99turborock's Avatar
I have a 99 2500 24 valve, 5spd, longbed, 100K, when i go and start the truck in the morning, the engine turns over for 15 seconds before stating. Pluging it in does not help. The truck starts fine when it is warm. I seems to have problems when it has sat for longer than 4 hours or more. Sometimes (1 out of 5 times) it will start right up when is cold. I just bougth this truck, the old owner had a new injector pump put in it. I held a test light to the intake heater an it was fine. ANY IDEAS? Could the injection pump not be timed right? If anyone has any idas i would really be greatful. thank you
Old 02-03-2007, 12:25 AM
Devin_01's Avatar
What is your fuel presure at?? Maybe check your fuel filter. It sounds like a fuel problem to me.
Old 02-03-2007, 12:31 AM
Not sure on the pressure. Someone else said the same thing. That will be the first thing i will check. The filter is new i think it was put in with the injector pump. Thanks for the info.
Old 02-03-2007, 07:41 PM
gunnie's Avatar
could be air intrusion also, sometimes you can get air in without fuel leaking out
Old 02-04-2007, 09:19 AM
runningbird's Avatar
sure sounds like your loosing your presure overnight. check your fuel presure and lift pump. do you hear it come on???
Old 02-04-2007, 09:39 AM
Hay, when i turn the key i can hear the lift-pump come on, I agree with maybe it is losing pressure after is sits. thanks for the info, i plan to put a fuel pressure gauge in and see it that is the problem. I will let you al know when i figure it out. thanks
Old 02-04-2007, 11:48 AM
fschiola's Avatar
The lift pump can still sound like it's running without pumping anything. The only way to tell for sure is to test the pressure.
Old 02-04-2007, 12:04 PM
I have been reading all the old "fuel pressue gauges" stories, an i cant find a common brand that works well for a 1999 24v, I want to order one asap. I am also looking to redo my transfer pump system, any good after market pumps, thanks for all the help !!
bert01ctd
10-04-2007 04:10 PM
wadecool
09-05-2006 08:12 AM
12valve
21
12-02-2005 11:56 AM
haulywood
06-10-2005 05:56 PM
yrusoslow2
13
02-17-2004 03:43 AM
Quick Reply: Hard start in morning
