Hard Brake Pedal
Old Sep 25, 2005 | 11:02 PM
gabbyfan's Avatar
Hard Brake Pedal
After using the brakes frequently like parking or backing a trailer up the pedal gets very hard to push and does not stop the truck. Any ideas would be great
Old Sep 25, 2005 | 11:37 PM
oestreich84's Avatar
My first guess would be the vacuum pump, but I am sure someone else will chime in soon.
Old Sep 26, 2005 | 01:56 AM
dieseldel's Avatar
My truck has always done that. If you pump the pedal too many times you use up all the stored vacuum, and braking is very hard. Rev up the engine a bit to 1500 or so, and you can pump up some vacuum a little more quickly.
-Del
Old Sep 26, 2005 | 05:37 AM
Andy505's Avatar
I dont know about you guys but my truck uses hydroboost power via the power steering pump for the brakes and not the vacuum pump, which is used only for the HVAC vents in the cab. I would think your guys trucks would be the same, just look behind your master cylinder, see if there is a hydrobooster there or a vacuum booster.
Old Sep 26, 2005 | 10:01 AM
infidel's Avatar
'94-'96 use vacuum boost and it is totally normal to use up all the vacuum by braking several times while idling. Either high idle it or add a vacuum reservoir to correct this problem
Dargo
Jan 12, 2018 07:45 PM
xp8103
19
Aug 20, 2008 05:10 PM
yamroamer
Sep 5, 2007 06:06 PM
capt.Ron
Mar 16, 2005 10:36 PM
Idaho Guy
Feb 25, 2005 10:01 AM
