H2 wheels on 3500?
Old Oct 16, 2007 | 11:19 PM
MJ4BTA's Avatar
H2 wheels on 3500?
Is anyone here running Hummer H2 wheels on there 3500? I have seen alot of pics on 2500's, but no 1 tons. The reason I ask is that I am using Dodge dana 60 knucles and unit bearings for the outers on my 8 lug axle conversion, but I am not sure if the larger 3500 calipers will clear the inside of H2 wheels. Is there anyone that has a measurement of how far, if at all, the caliper sticks out past the wheel mounting surface on the 3500's? I know the 2500 system is about 0.200 under the wheel mounting surface. All of my info is based on 2500 axles being the 7500# gvwr listing and 3500 being the 8800# gvwr listing. But it may be single rear wheel 7500# and dual rear wheel models 8800#? Any thoughts?
Old Oct 17, 2007 | 12:17 AM
Tate's Avatar
AKAIK, 3500 and 2500 front end parts are the same, with the exception that the 3500 has a bolt on spacer on the front.
Old Oct 17, 2007 | 02:03 PM
fiveology's Avatar
The 7500# gvwr 2500 axle is a Dana 44 not a Dana 60, it was only used in V8 gas 2500s. The 8800# gvwr is the 2500 Dana 60. The 3500 will have a gvwr of 9500# or higher. The only difference between a 2500 and 3500 Dana 60 is the dually adapters on the 3500, the brake parts are the same.
Old Oct 18, 2007 | 08:58 AM
MJ4BTA's Avatar
Oh thats right, I forgot about the Dana 44 2500. I just got all tha parts for both GVWR's. All the 8800 stuff works fine in the front. I used the 7500 caliper with the 8800 pads and 99 Ford E250 c-clip Dana 60 rotors for my rear disc conversion. It was a good thing I grabed both sets, so I could mix and match for the rear. Thanks for the input.
Old Oct 18, 2007 | 05:26 PM
fiveology's Avatar
Glad it worked out for you. What did you put the axles under?
Old Oct 19, 2007 | 11:52 PM
MJ4BTA's Avatar
There going under my 92 Jeep Comanche with a 93 4BTA/NV4500. The stock axles with chromo shafts and Detroit TruTrac differentials have worked good so far, but I think Im pushing the limits. http://s6.photobucket.com/albums/y23...PBash07009.flv
Old Oct 20, 2007 | 05:33 PM
falstaff's Avatar
They fit fine on my 2006 SRW 3500!
Tree DR
Dec 1, 2008 07:14 PM
dragginlx
15
Mar 9, 2007 11:32 AM
tontof18
Sep 28, 2006 07:59 PM
ptgarcia
Sep 12, 2006 06:04 PM
