gutting out the AFC housing?
Old 04-14-2009, 10:34 PM
kyle_truck_pull's Avatar
Question gutting out the AFC housing?
has anyone actually just gutted the AFC housing by taking out the the diaphram and rods? I guess if you do this it will let your truck have full fuel at idle and low boost. because normally with the AFC housing it wont let you have full fuell until a certain amount of boost. can anyone tell me more about this? thanks!
Old 04-14-2009, 11:21 PM
YOUNG GUNS15's Avatar
if you still want to drive it on the road i wouldn't do it, your truck will buck like a wild bronco
Old 04-15-2009, 03:47 PM
SilverHoss99's Avatar
If you are looking for a ridiculous amount of smoke. I had it done for about 3 months all it does is make it hard to drive without smoking everyone out and kills mileage too. Leave AFC intact and adjust star wheel.
Old 04-15-2009, 04:03 PM
Tate's Avatar
If you take the diaphragm out, you will be feeding boost into the oil side of the pump. Not good. If you are going to gut the housing, take the rod out of the front of the housing, the foot will drop out, and reinstall the rod. Keep the foot around, you will want to reinstall it.
Old 04-15-2009, 04:25 PM
97 D-Tec's Avatar
you dont want full fuel at low or no boost why? it basically puts the fire out so to speak which means heat and turbo lag. Use ur afc as a tuning tool ull be much better off
Old 04-15-2009, 08:05 PM
i was wanting to do this to an all out pulling truck im workin on, wouldnt it be a good idea? im wanting lots of fuel during spool up like alot of the other trucks, i didnt know if this would do it or not. it probably wont help at all then i guess if i did it, thanks!
kelownadiesel
07-29-2007 12:32 AM
SilverHoss99
05-09-2007 05:14 PM
MikeyB
04-10-2004 09:01 PM
Quick Reply: gutting out the AFC housing?
