gov. springs
Old 04-10-2006, 01:29 PM
Boosted12's Avatar
gov. springs
hey, will a 3 or 4gsk gov. spring give me more low and top end power thoughout all rpms? I am only makin 1000 degrees for temp too with a #0 plate. what else could give me more performance for cheap besides doin a turbo , injectors, or delivery valves?
Old 04-10-2006, 03:09 PM
halerazor's Avatar
a gsk won't add any power, but it sure does feel like it. it allows you to run higher rpms and fuel all the way through. i'm amazed your 0 plate has not trashed your tranny, you better save your money for a tranny because your gonna need it
Old 04-10-2006, 03:14 PM
Boosted12's Avatar
its still not that fast, anyways my tranny was rebuild right before i got it, so i dont know it it was build good or not, cause off the line to the boards, i have no slippin anywhere, well i need a lot more RPMs too, right now i dont have very many
Old 04-10-2006, 03:18 PM
Boosted12's Avatar
hey, how do u like your 370 injectors??
Old 04-10-2006, 04:15 PM
halerazor's Avatar
370's add a ton of power, but i wish i would have spent alittle more money and went with some edm injectors. for the money though you can't beat them
Old 04-10-2006, 06:29 PM
TxDiesel007's Avatar
perfectly said..
and while ur at it, go with the 4K kit, it seems to be the better option, and once its in there, u dont have to take it apart again and mess with the pump anymore. I have it. I too second the motion on the zero plate, your tranny must have nine lives, especially if you beat on it....
Rick
Old 04-10-2006, 09:02 PM
Abbynormal's Avatar
Hey - do a search on here for "free GSK" its a string from Gunracer. He tells how to put washers in above the governor springs and get over 3000 rpm.
Old 04-11-2006, 01:22 PM
Boosted12's Avatar
yea, i want to do the thing that gunracer did instead. now i was lookin at my AFC and its cracked, where can i buy a new afc?
Old 04-11-2006, 01:39 PM
Abbynormal's Avatar
Hmmm ATS has a new ATS spring kit.....
http://www.atsdiesel.com/ATSWebsite/...Mechanical.asp
Also Piers or Haisley or some of the other sites would be good to check
Old 04-11-2006, 01:54 PM
Boosted12's Avatar
all i need is the cover
Old 04-11-2006, 02:06 PM
Boosted12's Avatar
http://cgi.ebay.com/ebaymotors/Holse...QQcmdZViewItem
is this a good turbo=way more power??
Old 04-11-2006, 03:28 PM
gunracer1's Avatar
it is the old 8 blade design and it has a big t4 style exhaust flange and a 19cm housing, also big.
Old 04-11-2006, 03:34 PM
mr T's Avatar
u have a 100plate...look at the profile of that plate...thats the fueling u will get over 2700rpms...now add whatever gsks and that profile will just stretch over the wider new rpms...so technically ur biggest fuel surges will come on a couple 100 rpms later with a 3k gsk and another couple 100rpms later with the 4k.
if u had a 0 plate nothing should technically change
fishin fever
03-13-2006 06:46 PM
boughtadodge
13
09-03-2004 10:31 PM
Diesel-Dan
23
08-29-2004 07:19 AM
yrusoslow2
12-31-2003 06:26 AM
dodgeman01
12-22-2002 09:55 AM
Quick Reply: gov. springs
