going for the 5 x .012 injectors
Old May 1, 2011 | 08:31 PM
sooty's Avatar
im down to either low budget diesel performance at 450. plus the 150. core, i dont want to let the originals go, living in cal, who knows if well get emissions tests in the future, and the ddp's at 649. (no core). unless i can work ryan to lower the core price, im still only 50. difference, goldfarb will sell cores for 15. each, for 100. shipped, ill save 50. for those that run either, would you do it again, or are there any other preferences? either way, im doing it tomorrow. im looking to install bigger exhaust, he351, new i/c pipe, and then the injectors, all at once.
Old May 1, 2011 | 11:49 PM
jimbo486's Avatar
My 5x.012s from LBDP will be here tomorrow. I'll let you know how they perform on mine as soon as I get them in.
Old May 2, 2011 | 08:52 PM
jimbo486's Avatar
Holy!! I hope you bought from LBDP. I've only driven up and down my street and immediately felt a huge difference from my 4x.014s!! These 5x.012s burn A LOT cleaner than my 4x.014s also. DDP injectors are honestly junk, overworked marine injectors that are too expensive. You won't be disappointed with LBDP.
P.S. They're prices are going up on June 1st but they'll still be the cheapest of all in the market.
Old May 2, 2011 | 09:10 PM
sooty's Avatar
thats all i needed to hear, i figured id wait to hear from you, im odering tomorrow, thanks jimbo!
Old May 2, 2011 | 09:14 PM
jimbo486's Avatar
Call Nick and tell him I sent you. He just might waive the core charge for you. (682) 365-9629
Old May 2, 2011 | 10:18 PM
jimbo486's Avatar
I was recommend by Weston through Nick to have the sleeves/adapters cut down to .030". That was based on the rest of my mods so it could be a little different for you. Nick is very knowledgeable having been trained by Weston and will be able to steer you in the right direction. You don't have to have the sleeves cut but either way, you'll need them since the new injectors will have 7mm nozzles.
Nick just now informed me that it might take a bit 'cause he has to order more nozzles. Absolutely worth the wait though!!
Old May 3, 2011 | 02:08 PM
sooty's Avatar
thanks jimbo, he went for the goldfarb cores, and ill be tailored the same as your 5 x .012 injectors, the little time he has to get them together, will be fine with everything ive got to keep me busy, ill be a couple weeks when i can address the install, ill post results.
1992gen1_fan
Jul 13, 2011 08:07 PM
DarrinGT
Aug 22, 2008 10:49 AM
KRB
May 20, 2007 06:20 PM
mpfireman
Dec 16, 2004 04:15 PM
BIGOKIE
Jul 21, 2004 05:53 PM
