Goes dead
Old Jul 6, 2009 | 09:30 PM
cjdakota's Avatar
Unhappy Goes dead
A year ago when my truck was shut off on a humid day and at normal temp it would not start. like no juice or nothing. Then 45 min later it fired right up. My mechanic told me that the VanAaken box goes into a logical lockout and I would have to deal with it or place the ecm or pcm to a new spot where they would get more air. Well its doing it more often and it does not even have to be up to temp, like150 and it does it like at a drive through window at a bank while trying to be courteous to others. Sure enough 25 mins later it fired right up. Any ideas anybody??
Old Jul 6, 2009 | 11:04 PM
Lil Dog's Avatar
I would have the codes pulled from the ECM. Hot start problems are an early indicator of a weak VP44 injector pump. The P0216 would be what I would expect.
Old Jul 7, 2009 | 06:04 AM
cjdakota's Avatar
I will have it checked soon and will remember that code. Now yesterday I went for a 1 hour ride came back and it started. Will that code show up only if it does not start? Thanks for replying by the way.
Old Jul 7, 2009 | 06:28 AM
67HotRod's Avatar
It may/may not show a code. We have run water over the pump, not the electronics and have started them up again, shortly after. Your probably close to a new VP44.
Old Jul 7, 2009 | 08:46 PM
cjdakota's Avatar
Goes dead
Well The code only read that there was a loss of communication and there was a loose battery terminal so we unhooked the negs to reset codes and I will see if it happens again but to clarify when I say it is dead I mean as if no power to the starter no tick no nothing. I am wondering if its a bad starter that was put on last year. Shop did not have time to look too much unfortunately.
Old Jul 8, 2009 | 12:10 PM
Lil Dog's Avatar
Ok, thats a totally different problem than Hard starting hot..
I would clean all the battery connections and check the cables for rot. Then any connections to the starter and solenoid.
Old Jul 8, 2009 | 08:57 PM
cjdakota's Avatar
Goes dead
Thanks. I have done that and we will see tomorrow.
Old Jul 14, 2009 | 07:30 AM
cjdakota's Avatar
Goes dead
It appears to be something going on between the ign solenoid because if I cross the solenoid wires it starts. Still have to get to the shop
BossHogg
May 7, 2012 09:07 PM
thenrie
Sep 25, 2011 04:47 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
converteddzlr
Jul 29, 2005 01:35 PM
