fuel shut down solenoid
Old Oct 28, 2012 | 10:14 PM
csa's Avatar
csa
Ok guys my fuel shut down solenoid is not engaging or pulling the lever up. if i turn the key on and manualy pull it up it will stay up and i can drive it as soon as i shut it off i have to manualy pull it up again. It will shut down as soon as i turn it off. So is it the shut down solenoid or relay? I have 12v at the relay on 2 of the three prongs so im thinking solenoid..your thoughts, and were do i get a new one or is this part severiceable?
Old Oct 28, 2012 | 10:49 PM
chariotdriver's Avatar
I believe in 98 they replaced the fuse link to the start solenoid with a fuse. It's pretty good sized, like 40 or so amps as well. The solenoids usually wear/last quite well; not so much with the relays, they eat the contacts from time to time. I would try jumping the relay, use stout wire because it does take quite a few amps to get it to jetk the start lever up. As for your 12 volts on the relay prongs.......one of the big ones should go to the hot side of the battery either through the fuse link or a fuse the other big one should go to the solenoid then you have one to ground and one to the key/start.
Larry B's has your good quality parts.
Old Oct 29, 2012 | 08:46 AM
CarlJensen's Avatar
Here is Joe G's write up on the fuel system. Good write up. Probably junk in the solenoid or corroded fuse link.
http://www.cumminsforum.com/forum/94...m-writeup.html
Old Oct 31, 2012 | 07:52 AM
casey sohc's Avatar
shatten relay!
my relay shat! and the solonoid worked the same way.all i had was a solonoid from my fog lights and it made crappy contact so i bent all the prongs a little so it makes contact and prang it works.yes its only 40amp not 60 (and $3.99 vs $30)but it got me back on the road,it is very hard to get out of the truck and lift the hood to start the truck in the drive thru at timmies(nectar of the gods here in canada)there is some great videos on youtube showing what to do.good luck
Old Oct 31, 2012 | 06:04 PM
csa's Avatar
csa
well after checking for voltage at solenoid and relay i discovered it was the relay..crap **** thing still cost $80 but works just fine thanks guys
Old Oct 31, 2012 | 06:34 PM
infidel's Avatar
Buy an extra for the glove box for $15 here> http://www.fostertruck.com/dodge/default.htm
Old Nov 2, 2012 | 07:59 AM
CarlJensen's Avatar
While you are at it, put it in a remote location. I did and I pull it when leaving the truck for a while. Hard to start with no relay.
Old Nov 2, 2012 | 10:14 AM
casey sohc's Avatar
holy crap!i had never thought of that....even a remote switch in the ashtray.it's only a foot away.hummmm maybe you are on to something.thanks.
GLHS
Jan 20, 2007 10:55 AM
Rare1
May 24, 2006 06:36 PM
12valve
Dec 25, 2005 01:29 AM
FROGGIE
Sep 27, 2005 04:19 PM
mainer
Jun 21, 2005 05:58 PM
