Fuel pressure gauge
Old 10-20-2005, 08:21 PM
xmr
xmr's Avatar
Exclamation Fuel pressure gauge
As the new owner of a not so new diesel truck, a 1999 2500 24 valve , I was trying to find a fuel pressure gauge at a reasonable price. the only one that I have found was $239 and that seemed a bit too pricey. Are there other options??
Old 10-20-2005, 08:25 PM
xmr
xmr's Avatar
oops clicked wrong forum. Sorry
Old 10-20-2005, 08:28 PM
Dr. Evil's Avatar
UH, yeah...get a mechanical guage. This will require running fuel into the cab but its no big deal.
How about $39.95 ??
http://www.dieselmanor.com/isspro/r5..._fuelpress.asp
BTW, fill out your signature so people can accurately answer your questions.
Old 10-20-2005, 09:45 PM
TRCM's Avatar
You can get an autometer 1-60 psi from JEGS for 20-30 bucks.
Old 10-20-2005, 09:53 PM
Dr. Evil's Avatar
Lighted?? Cab mount??
Old 10-20-2005, 10:55 PM
TRCM's Avatar
it is a standard gage. would need an isolator if you don't want fuel in the people space. 1 1/2" gage, liquid filled. not sure about being lighted, but probably not. 3 color choices.
part number 555-41012 jegs black or 105-2173 autometer black
go to jegs website and check it out.
I'm planning on going with a cyberdyne digital 0-80 psi oil press gage for mine. Gonna run me about 70 bucks total.
No one makes a 0-40 or 0-50 psi gage that I have found, and I prefer digital so I can see press instantly without havign to read the dial since it will be mounted on the floor in front fo the shifter.
Old 10-21-2005, 09:27 AM
infidel's Avatar
TCRM, make sure the Cyberdyne comes with a good warranty.
12 valve lift pump pulsations kill senders even with a gauge snubber.
I went though three senders before I gave up and went with a mechanical, one sender only lasted 15 minutes.
60 psi is the best psi gauge for a 12 valve, that way at normal operating pressure the needle is pointing straight up.
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
Quick Reply: Fuel pressure gauge
