Fuel Pressure Gauge?
How necassary (if necassary) is one on a 12v? I know that the lift pump is a lot better than one on a 24v, but at what HP/Torque would a gauge be recomended for a 12v? If I buy one would 0-35PSI be sufficient? My goal for HP is around the 500-550 mark at the wheels ... If anyone has any input it'd be appreciated!
Hey Chris , Yes , fuel pressure gauges are very useful on 12v trucks, lift pumps do fail (although not very often) it can also help diagnose lowered fuel pressure due to a plugged fuel filter , or pre-filter screen , as well as overflow valve problems.
The 35 lb gauge will work , sort of, here are the specs:
Normal fuel transfer/lift pump pressure specifications are 17 - 22 psi at idle and of 25 - 36 psi at 2500 rpm (no load).
You can shim the overflow valve for a little more pressure, but then you will need a gauge that reads higher, too much pressure will blow seals.
I plan on running a 60 lb fuel press. gauge , when money allows me to do so.
Not really nessesary, but its nice to have, and it serves as an indicator when u have a plugged fuel filter.... Id go 0-60 on one,
RIck
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
