Fuel line help....
Old May 12, 2007 | 02:16 AM
keithw1975's Avatar
Fuel line help....
Two questions.....
1. What is the best method for cutting braided stainless steel fuel line without making a messy end with frayed wires?
2. What symptoms would you expect if you were getting a little bit of air into your low pressure fuel lines either before or after the lift pump?
Keith
Old May 12, 2007 | 08:48 AM
csutton7's Avatar
cold chisel wide enuff for the line and smack it hard with a 2lb mallet--you could wrap the line with electricians tape also before you whack it---
hard starting for one symptom---what symptoms do you have??? chris
Old May 12, 2007 | 09:06 AM
John Faughn's Avatar
Tape & a die grinder with cutoff wheel ,
Pressure test the fuel tank , about 3 lbs. of air pressure , than look for fuel leaks .
Old May 12, 2007 | 10:40 AM
keithw1975's Avatar
I have had a rough idle that comes and goes as well as a fuel pressure gauge that jumps around by about 1 psi. It always starts ok as long as the lift pump runs for a second.
I installed Aeroquip -6 AN fittings and where they screw into the lift pump I am suspicious there might be air leaking in.
Keith
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
RoadDiesel
Jun 16, 2007 09:24 PM
Begle1
19
Aug 25, 2006 11:31 PM
