fuel filter for transfer tank
Old 10-04-2008, 09:57 PM
beardedone's Avatar
I have just installed my aluminum cross the box tank. I am going to plumb it into the vent line of the stock tank but I would like to put an in line filter on it. What kind of suggestins do you have that have worked without breaking the piggy bank. Where can I order them. This is a gravity feed system. Thanks
Old 10-05-2008, 10:30 AM
rich's Avatar
i use the cheap inline filter that you can get for 5 bucks it will keep a lot of the crud out
Old 10-05-2008, 11:12 AM
AH64ID's Avatar
Something like the WIX 33123 would be a good filter for this app. You can use WIX base # 24309 with it... It should do a decent job of gravity feed if you can plumb it well.. .but you would be best off with a small transfer pump.
If you don't want to deal with a large filter than something like FF5079 (fleetguard) or WIX 33270.
Old 10-05-2008, 07:17 PM
haulin-rv's Avatar
fleetfilter.com has filter heads at a great price. Then you can use a spin on. I run 2, first a 10 micron fuel water sep filter then a 5 micron filter.
Old 10-08-2008, 11:07 AM
dezeldog's Avatar
I to have a gravity feed tank and use a racor 2 mic w/s. I believe it is a R13s.
Jim
Old 10-08-2008, 03:32 PM
johnh's Avatar
that's what i use, my final filter is a racor 2 micron water sep/filter on the frame before the lift pump
Old 10-09-2008, 08:54 PM
carl48's Avatar
i used a 86377 car quest filter it is 2 micron i gravity feed through it to the main tank. i used this filter because i stock it for my larger trucks
90 power ram
05-29-2013 06:01 PM
Stamey
06-27-2008 02:04 PM
TJE
12-10-2007 11:33 AM
durasmack
12-17-2006 10:09 AM
TJE
10-25-2006 10:21 PM
Quick Reply: fuel filter for transfer tank
