Fuel Cap
Old Mar 26, 2011 | 12:26 AM
Jer12377's Avatar
From: North Haven,CT "Living in occupied teritory" & Barton,VT
Fuel Cap
I have had a problem with my fuel tank imploding cause the fuel cap is not venting. I lost prime the last year hauling my tractor and bought a new one. It was one that has that 1/4 turn to vent it and it worked fine till this year. Does anyone know where do I get a vented fuel cap for my truck?
Old Mar 26, 2011 | 12:17 PM
Richie O's Avatar
366 Spring Chicken
Go to a parts store and they can look up by application. Make sure they give you the diesel cap. Go to a real parts store like NAPA or Carquest. Somewhere that actually has a real counterman, not a numb nut wannabe.
Old Mar 26, 2011 | 04:23 PM
Bogie's Avatar
Stant Part # 10819D Diesel Only Pre-Release Fuel Cap Green
Old Mar 26, 2011 | 08:16 PM
NE frmhnd's Avatar
Are these supposed to vent through the cap? My tank doesn't vent either, I've been turning it loose a 1/4 turn to let air in.
Old Nov 8, 2011 | 04:15 PM
I'm digging this one up since I can't seem to find the right cap either. I need some sort of venting on my tank since it's pulling the plastic tank in due to the vacuum it's creating.
I've read up a little on that Stant cap, and it seems it's a pre-release cap...only releases positive pressure in the tank, not venting the tank so you don't have a vacuum/negative pressure in the tank.
Anyone know for sure what vented cap to use?
Old Nov 8, 2011 | 05:04 PM
Why not check out their website:
http://www.stant.com//Automotive-OEM...el---Oil-Caps/
Permits fuel system to normalize during natural vacuum situations.
Seems like they provide what you're lookiing for, and Rock auto has them for $6.00
Old Nov 8, 2011 | 06:37 PM
ChrisLib's Avatar
Its diesel were talkin about here, no worry for EVAP emissions...just drill a .060-ish hole in the darn thing and be done with it.
Old Nov 8, 2011 | 07:05 PM
BILTIT's Avatar
Mine is always pressured up some when i remove the cap.
Old Nov 8, 2011 | 10:35 PM
I wouldn't mind a bit of positive pressure...but mine is creating negative pressure and is collapsing the tank. Especially when I'm at 1/2 tank or less.
Where to drill the .060" hole? Up the center of the cap, on the inside?
Old Nov 9, 2011 | 11:52 AM
ChrisLib's Avatar
Yeah, just thru the inner white portion and NOT all the way thru, don`t want any moisture finding its way in there. Before you do that though, might want to check the vent line to the tank and make sure its not plugged/restricted.
Old Nov 9, 2011 | 01:35 PM
9MM's Avatar
9MM
I just leave my cap about a turn or two loose. Works good as every time I got to the parts store I forget to one. Shoulda done it when I worked for a parts store
Old Nov 9, 2011 | 02:22 PM
Jer12377's Avatar
I bought the green diesel cap, and for a crazy price, from Advanced about a year ago. It has a 1/4 turn you have to back off after you tighten it or it will do the same thing to the tank. Knowing what I do now I would have drilled the hole. The special diesel cap is worthless. Just my $.02...
Old Nov 9, 2011 | 03:52 PM
Thanks for the info guys...I'll check my vent tube of the tank first. If that is hooped then I'll drill out the cap.
VFDFireman
Jan 5, 2008 06:47 PM
sterling
Oct 19, 2007 05:32 PM
ajpulley
Jan 16, 2006 04:21 PM
rjrkihap
Oct 4, 2005 05:09 PM
GlennRMK
Jul 22, 2005 10:57 PM
