Front Drive Shaft
Old 05-20-2010, 10:51 AM
gsqhtr's Avatar
Front Drive Shaft
I noticed that I can slightly twist my front drive shaft when the truck is parked. Should there be any monement? Havent tried it in 4WD, I would assume all of the play would be gone? Knock on wood I am not having any problems shifting or clunking. Thank you in advance.
Old 05-20-2010, 05:35 PM
Dirk5.9's Avatar
There was a little play in mine the other day when I had it on the lift. I'll be replacin' my u joint on the front driveline this next week. I don't think you want any play at all......but I'm not 100% sure
Old 05-20-2010, 09:23 PM
rockcrawler304's Avatar
You will have a little bit of play. This is normal.
Old 05-21-2010, 11:52 AM
gsqhtr's Avatar
Thank you, I checked the U-Joints and they all appear to be fine. No clunking when shifting out of park or putting in reverse.
MCMLV
10-19-2004 08:36 AM
TON4FUN
08-02-2004 07:58 PM
cwbronc
12-21-2003 02:48 PM
shaft
06-30-2003 02:37 PM
bkay
12-12-2002 05:22 PM
Quick Reply: Front Drive Shaft
