front diff drain
Old 09-10-2011, 12:18 PM
DC199512V87's Avatar
front diff drain
where is a good place to drill and tap a drain plug into the front diff of my 1995 so i don't always hafta b cleaning the gasket off and buying a new one every time i change the oil? front, back, right on the bottom? ill b taking off the cover to drill and tap this time so i don't hit any gears....
Old 09-10-2011, 11:08 PM
oldblues's Avatar
hi
i dont use a gasket just some mopar diff silicone sealer from mopar parts dept .
one tube would be enough for app 4 covers easily ?
the frount diff does not turn unless in 4 wd so it only rarely needs changed for me ?
Old 09-11-2011, 12:25 AM
ok....i was gonna use gaskets but thats impossible to find in my town for some reason so i will use silicone. i know that about the front diff but i bought it used and just wanna do it so i know where things are at...peace of mind. funny that the rear has no drain either...
Old 09-15-2011, 10:52 PM
joem's Avatar
Just use blue rtv, works great and I only change my front diff fluid every 100k anyway.
Old 09-15-2011, 11:00 PM
Purplezr2's Avatar
They even make gaskets, I just use gasket make, gives me a chance to look at the gears.
Old 09-16-2011, 10:11 AM
infidel's Avatar
I think it's good that you have to remove the cover, gives you a chance to wipe the sludge off the bottom of the diff.
If I were to tap in a drain plug it would be on the bottom of the differential itself, not the cover.
100k mile changes using synthetic Royal Purple oil so it's no big deal for me to remove the cover and silicone it back on.
Remember the factory fill spec on the differentials is 3/4" below the bottom of the fill plug in the front 1/2" in the rear.
If you fill to the bottom of the hole you're just inviting higher fluid temperatures and eventual leakage from the axle seals.
Old 09-16-2011, 10:33 AM
ended up using black gasket maker and not drilling anything....just another place to create a leak. And i used Mobil shc 629 with a tube of limited slip additive. didn't know about the fill level though. i filled to the bottom of the drain, but the front was higher than the back so i shouldn't b overfilled. good stuff to know
Old 09-16-2011, 11:48 AM
joem's Avatar
I also filled mine to the threads- my truck was up on a lift so the axle was tilted a bit forward though. I just used 80w90 as the only time its used is in the super cold snow or just a few hundred feet on a steep gravel road when pulling our trailer to the huntin spot
Old 09-17-2011, 11:30 AM
johnh's Avatar
these differentials are not designed to be drained very often because they don't need it i personally have only changed mine to put in a different type (synthetic) in 260,000 miles
Old 09-19-2011, 09:57 AM
infidel's Avatar
Dodge says if you don't tow that you don't have to change the diff fluid at all.
Not sure if I believe that...
afate45
06-07-2014 12:08 AM
klx650a2
01-10-2008 12:08 AM
DodgerDoob
12-27-2006 06:41 PM
rjweiss
87
05-27-2004 04:56 PM
wooff
05-01-2003 11:22 AM
Quick Reply: front diff drain
