Front Axel Leaking
Old 11-14-2008, 02:01 PM
91rangerturbo's Avatar
Front Axel Leaking
My Dana 60 is leaking around the what looks like the 4wd actuator (closer to the passenger side of the truck) where is bolt's to the axle itself. Is there a gasket for this? I looked online at some local parts houses and didn't turn anything up. It just started leaking after the truck sit for about 2 months.
Or should i just use some black RTV and roll on? And is there anything i need to be careful with when removing the actuator itself to repair this?
Old 11-16-2008, 08:08 PM
Anyone care to chime in?
Old 11-17-2008, 02:47 AM
Flatbed24v's Avatar
I would also like to know this cause mine does the same thing
Old 11-17-2008, 06:07 AM
I couldn't find a gasket for it. I am sure the dealer probably has one for it. But i would think draining the front end and cleaning it up really well. Then some black RTV would seal it up just fine. I still haven't got around to doing it yet. I was waiting to see if someone had fixed this before.
Old 11-17-2008, 07:21 AM
sheriffav8r's Avatar
The gasket comes with the CAD replacement part. It also has all the retainer rings for the CAD itself. I think the whole thing is about $100 and well worth it....
http://www.1aauto.com/1A/4WDrive/Dod...ze/1AFWA00007/
Old 11-17-2008, 08:24 AM
nickg's Avatar
No need to drain the diff to remove the CAD, there's not enough oil in the tube to drain out and if there was you'd only loose a couple oz,
Old 11-18-2008, 08:51 AM
Well my CAD works just fine still. I guess i can just use RTV and pull it off and re-install. I don't see replacing something that there is nothing the matter with it. Just a leaking gasket.
Old 11-18-2008, 10:03 AM
REF>Lancer's Avatar
That's what I'd do,the black RVT is good stuff.
lilsuzuki4x4
09-01-2011 01:50 AM
blb4742
11-28-2009 06:59 AM
drolex
03-25-2009 12:51 AM
rangerst
02-01-2004 12:41 AM
JImbo1
04-09-2003 07:46 AM
Quick Reply: Front Axel Leaking
