rear axel leaking gear oil
Old Jul 28, 2009 | 08:40 AM
blb4742's Avatar
I have a smoking rear passenger wheel after a long road trip. After further investigation I found gear oil on the inside fender well and what looks like dissintigrated brake pad on the inside of the rim. Any suggestions? is is the rear axel seal and about how much to replace. I already know that I will have to replace the brake pads, but how about the real seal. Give me some input. Thanks.
Old Jul 28, 2009 | 06:09 PM
dodge35000's Avatar
A disintigrated brake pad sounds like a sticky brake caliper possibly heating up the rotor and hub. Maybe the excessive heat is what caused the seal to fail.
Did you feel any drag or pull on that side? Do you hear any growling or grinding like a wheel bearing is going bad? A leaky axle seal should not cause a brake pad to disintigrate or smoke to come from the wheel unless you lost all of the oil on that side and the bearing was beginning to burn up.
The only way to really tell what is going on is to pull the wheel and get a better look. Also if you can post a pic a lot of the members would be able to help you.
Old Jul 28, 2009 | 08:25 PM
The Tank's Avatar
Nope mine did the same thing. why would you not get smoke? gear oil on hot rotor. put new wheel seals both sides good to go took napa a little to get them I want to say they where like 40 ish a piece different design.
Old Nov 28, 2009 | 06:59 AM
herb101's Avatar
Does anyone know the part# to rear axle seal. I have a SKF #28545 and I'm not sure.
Thanks advance.
Herb
drolex
Mar 25, 2009 12:51 AM
91rangerturbo
Nov 18, 2008 10:03 AM
winkle
Nov 12, 2005 09:35 PM
JImbo1
Apr 9, 2003 07:46 AM
yz
Nov 25, 2002 06:04 PM
