Front air ride on 2wd ideas...will it work??....
Old 08-17-2009, 05:09 PM
Jordan5687's Avatar
Ok, here's what I'm thinking...I've seen those air bags that you can put inside of the coil springs....only levels it about 1000# is what I've seen...I'm just wondering how it'll hold up to the weight of the front end of my 06, it's a 2wd....??? Anyone know how they handle and ride? I think they're firestones or air lift...not sure.
Or what I'm thinking is take out the coil springs and installing some airbags in their place. Still using the shocks, will this work?...or do you think it wont be as stable as the coil springs...I mean I know the coils dont hold the frame and that whole suspension together they kinda set there, but I'm just checkin.
Old 08-17-2009, 05:55 PM
Jordan5687's Avatar
One more thing, I have bags on the rear of my truck and am looking at lowering the rear of the truck, just taking those spacers out from under the leaf springs. I've seen it done and just putting those spacers on the top to use the same u-bolts and all....but wouldn't you want to put the spacers inbetween the overload leafs and the other leafs to keep the overloads kinda in the same position as they were before?? And because I have the bags installed in the rear already is is still ok to go ahead and lower the rear?
Old 08-17-2009, 06:08 PM
cbrahs's Avatar
I installed a set of the firestone front bags for a friend on mine on his 03 dually. very cool item. it has only been a couple months so I don't have any longevity info for ya
Old 08-17-2009, 06:21 PM
Jordan5687's Avatar
Were they the ones that go inside the coils, or did you replace the coils....if you can find out how he likes the ride and feel I'd appreciate it!..thanks!
Old 08-17-2009, 11:17 PM
cbrahs's Avatar
he loves the ride. It was on a dually and he hauls a 11 foot slide in camper. We did a complete lorenz suspension and the firestone front bags along with 5100 bilstein shocks. They are the ones that go inside the spring.
Old 08-18-2009, 10:21 AM
FunFinder5's Avatar
Doesn't the shocks on the 2wd's go inside the coil springs? So either way you go I guess you're going to have relocate the shocks.
Old 08-18-2009, 06:13 PM
Jordan5687's Avatar
Yes the shocks do go inside the coils. I also found out that I can't take out spacers under the rear leaf springs cause....the 06 2wd....doesn't have any! lol....never knew it...oh well I'm trying to fab my own true air ride in the rear anyway. I'm not too sure if replacing the front coils with bags would do anything cause it may rub on some things....but I think if I find the right type and size it may work...I need to find a place that has many styles and sizes of bags. Not sure when I'll be able to start any metal fabbing, cause I'm in the process of putting up a shop right now from the ground up. But will def do this.
Anyone have pics of a stand alone air ride system in the rear?....or front? Want to see how they're mounted and all....I haul really heavy loads so I want to really be sure that axle stays in place lol. Thanks!
herb
07-18-2008 08:25 AM
Rushford
23
08-26-2007 07:21 PM
Bobcat698
04-01-2007 10:26 PM
Deezle98
05-11-2006 01:17 PM
12valve@heart
01-27-2004 01:25 AM
Quick Reply: Front air ride on 2wd ideas...will it work??....
