free gsk help!!!!
Old 06-26-2007, 02:26 PM
blueboy16's Avatar
free gsk help!!!!
i put in a free gsk washer mo and it starts up normal then when you rev it up it stays at 2100rpm and wont come down unless you put it in grear let out the clutch and put the motor under load
Old 06-26-2007, 03:15 PM
blueboy16's Avatar
anyone kno?
Old 06-26-2007, 05:42 PM
Muddin_dude06's Avatar
Adjust your idle down about a 1/4 turn at a time and that will fix it...
Old 06-26-2007, 05:47 PM
Lil Dog's Avatar
Maybe the washer is too big in diameter?
Old 06-26-2007, 07:13 PM
clutch1's Avatar
washers are hanging on the outer spring
Old 06-26-2007, 08:17 PM
blueboy16's Avatar
so do i just need to take them out and file them down?
Old 06-26-2007, 08:23 PM
clutch1's Avatar
anything to keep them from hitting the outer spring. what size did you start with?
Old 06-26-2007, 08:25 PM
blueboy16's Avatar
3/8ths and drilled them out with a 1/2inch drill bit
Old 06-26-2007, 08:28 PM
clutch1's Avatar
try loosening them a little
Old 06-26-2007, 08:33 PM
blueboy16's Avatar
one click or so? also one side was .050ths stud protusion stock and the other was about .071ths stock
Old 06-26-2007, 09:58 PM
Try adjusting the idle first, it is a heck of a lot easier and quicker than tearing it all back apart, if nothing else it's worth a shot. That is what I had to do with mine and it fixed the problem...
12valve2nv
06-08-2006 10:12 PM
plow
08-09-2005 04:25 PM
MR HYDROSEED
03-09-2005 10:49 PM
Got Smoke?
10-26-2004 03:57 PM
Quick Reply: free gsk help!!!!
