Fleetguard OEM air filter part number?
Old 11-14-2010, 09:25 AM
james1's Avatar
Question Fleetguard OEM air filter part number?
1. Would someone please tell me the Fleetguard part number for the OEM air filter (as opposed to the BHAF)? Cummins Power South just sold me the wrong filter.
2. Faith, would you add part numbers for the Fleetguard air filter, oil filter, and fuel filter to the "Part Numbers" thread in the Sticky? I find dealing with the parts desk at Cummins much easier when I have the correct part number in hand.
TIA
Old 11-14-2010, 11:58 AM
cseby's Avatar
fuel filter:
baldwin,bf788(with top gasket)
baldwin,bf988(no top gasket)
fleetguard:ff5018
napa:3358
donaldson: p553004
oil:
baldwin,bt7349-bt339
fleetguard,lf3959-lf3349, upgrade 3552
napa,27620-1607 upgrade 7620xe
wix,57620-51607 upgrade 57620xe
donaldson,p558615
air:
baldwin,pa2183
fleetguard,af4555m
napa,6343
wix,46343
donaldson,p530355
Old 11-15-2010, 10:19 AM
james1's Avatar
Originally Posted by cseby
fuel filter:
fleetguard:ff5018
oil:
air:
baldwin,pa2183
fleetguard,af4555m
napa,6343
wix,46343
donaldson,p530355
Thanks much.
I'm all confused.
I'm showing the fuel filter with the WIF sensor as Fleetguard FS1232 and the extra long one (without the WIF sensor) as Fleetguard FS1221.
I'm also showing the oil filter upgrade (stratapore) as Fleeguard LF3894.
Can someone tell me where I'm wrong?
Thanks again.
Old 11-15-2010, 06:23 PM
cseby's Avatar
i buy my filters at the international tractor dealer,so the ff5018 is most likely a filter with a tractor application.no sensor on it,never use them.i have switched to baldwin bf788 fuel filter,they are about $1.50 cheaper than fleetguard.i use the old lf3349(lube) as my dealer doesn't carry the upgrade.
Old 11-17-2010, 11:13 AM
james1's Avatar
Rock Auto shows air filter part numbers as:
1989 to 1992 models -- WIX46643
1993 model -- WIX46338
And the sizes (height, ID, OD) of these two filters differ slightly.
So I still need the part number for the Fleetguard air filter to fit my 1993 truck.
Help?
TIA
Old 11-19-2010, 07:59 PM
The '93 filter is different than the older ones.
AF25023
72dart
31
01-11-2010 12:32 PM
nfsommer
04-16-2007 09:21 PM
JKM
09-23-2005 07:37 AM
TurboAZ
06-15-2005 10:33 AM
Denis
05-21-2004 10:45 AM
Quick Reply: Fleetguard OEM air filter part number?
