Fitting Tires & Wheels
Old May 5, 2003 | 03:33 PM
duke1n's Avatar
Greetings, I have an 2002 Ram 2500 w/Cummins and looking to get some wheels and tires. My question is will a set of Mickey Thompson Classic II 16x10" fitted with 305R70 16 tires fit the stock truck without rubbing in the front? I think these wheels have a 4 7/16" back space. Also trying to find pictures of truck with different sized wheel/tire combinations to see what I like the looks of best. Thanks for any help.
Old May 5, 2003 | 05:37 PM
phox_mulder's Avatar
Re:Fitting Tires & Wheels
The stock wheel backspacing is in the neighborhood of 7 inches, so those wheels with only 4 7/16's will stick out about 2-3 inches more than the stock rims.<br><br>Because they stick out, you probably won't have any rubbing on the control arms, you might have some rubbing on the inside rear of the fender whilst turning.<br><br>I had rubbing with 315's on my Weld 16x10's with the same backspacing, even with a 2inch leveling kit on the front.<br><br>Here's some pics of mine stock, with the 2inch spacer and new wheels/tires, and with 4.5 inch lift and new tires/wheels.<br><br>https://www.dieseltruckresource.com/....php?album=149<br><br><br>phox
Old May 7, 2003 | 05:34 PM
Diesel Fumes's Avatar
I have 295/75/16 (33.4 inches tall) mounted on M/T Classic II. Phox is right, they stick out about 3.5-4 inches but, I like that look 8) No rub at all.
Old May 7, 2003 | 05:39 PM
FMF MX's Avatar
Thats the size tires &amp; wheels I have on stock suspension, they only rub at full lock when entering a driveway..Very slight. Has caused no problems..
Old May 7, 2003 | 11:43 PM
59Dsul's Avatar
I've got 305/70's on 16x10 Eagles. I had a slight rub on stock suspension when turning left (I think?). After the 2.5&quot; coils, I actually rubbed when turning either direction, but it was because of my mudflaps. For pics of this combo, check out my member's photo section &quot;Here&quot;<br>BTW, this was a 33 Swamper combo, same size as the 305's I put on last week. <br>andy
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
blackdevil
40
Sep 25, 2005 03:38 PM
Lurch519
Jul 14, 2004 07:00 PM
Gary C
27
Mar 11, 2004 07:42 PM
