figured out 1690 code
Old Oct 12, 2007 | 10:31 AM
skidooer76's Avatar
Talking figured out 1690 code
well I have been around and around with my truck lately it was hunting for overdrive and the check engine light came on with p1690 and p1693 codes showing, I tried cleaning all the grounds, sheilding the wire over the alternater, reseting the APPS, so I ended up replacing the lift pump with the Holley blue on the frame rail and it turns uot thtat it was the problem the truck was not getting enough fuel so it was defueling the truck and making it down shift, I just thought I would pass the info along.
Old Oct 15, 2007 | 01:07 AM
Clunk's Avatar
Thanks for the heads up skidooer!!
Old Oct 15, 2007 | 08:19 AM
Mike D's Avatar
Code 1690:
Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor.
I don't see how a Holly Blue pump fixed your problem? I'm glad your truck is running good again.
Old Oct 16, 2007 | 07:41 AM
skidooer76's Avatar
Mike D I tried everything else that I could get my hands on in the search fourm for the problems I was having I had planed on replacing the stock lift pump anyways so i did and the next morning i was going to take the truck to the dealer to see if they could figure it out, went out and started the truck to let it warm up and came out to leave and the checkengine light was off, got the code cleared and has been fine since, if you look at the description of the code that you gave which is correct if the lift pump was not sending enough fuel that makes perfect sense because the set amount to have in the ecm sensor and the amount the injection pump was sensing would not match up hense the code 1690 and the chek engine light.
Old Oct 16, 2007 | 10:16 AM
Mike D's Avatar
I don't agree with your explanation of the code, but I'm no expert when it comes to these trucks.
Like I said, I'm glad your truck it running good again.
Gitch
44
Feb 28, 2011 02:55 PM
ops_8_8
Aug 6, 2009 01:26 AM
DeweyND
Jan 9, 2009 08:28 PM
demsmiths
Mar 30, 2005 03:35 AM
Ohio Joe
Nov 24, 2004 03:09 PM
