Fan Clutch?
Old Jul 20, 2004 | 07:51 PM
RobP's Avatar
Fan Clutch?
I'm a newbie when it comes to these diesels, and I sure need some help from the gurus. At the end of a 100-mile drive, my 1990 D350 CTD (120K) overheated very slightly. When I parked, I noticed a funny smell sorta like railroad ties burning (you know, that burning creosote smell...). Anyway, I raised the hood and noticed a puff of smoke coming between the fan and the radiator.
I'm guessing fan clutch, but I ain't sure. The coolant level was OK, and I'd been driving for a while without any problems with the A/C on, so I don't think it is the T-stat.
How can I tell for sure? And what are the tricks in replacing it?
Thanks in advance for y'alls help.
Old Jul 20, 2004 | 09:52 PM
Tommy93w350's Avatar
Let the truck idle and turn the motor off while watching the fan blades. The blades shouldn't turn about 2 turns after the motor stops. Also, just try to turn it while the motor is OFF. It shouldn't free spin at all.
The fan clutch has a fluid coupling, it's possible that maybe some fluid leaked out and started smoking??????
I would get another opinion though
Old Jul 21, 2004 | 02:40 PM
apache's Avatar
Sounds about right. remember the threads are reverse or left hand. I used a strap wrench to remove mine and replaced it with a Hayden HD unit for $65. If its workin right it will really let you know when its hooked up from the fan noise if it gets hot enough.
Old Aug 28, 2004 | 10:40 PM
hippie's Avatar
What is the part number for the Hayden clutch, and where is a good place to get one?? Thx
Old Aug 30, 2004 | 11:44 AM
apache's Avatar
I got mine from a local AP. if you look up haydens site it will list the #. I think it shows superduty only for ours. mine was $70 or so. I think napa is $109.
Old Aug 31, 2004 | 11:00 PM
mopar2ya's Avatar
I had to use a big a$$ wrench to get my clutch off. I put the wrench on straight up and put a blanket around the wrench leaving the top 8 inchs exposed and then whacked it with a baseball bat....it broke free, and it was good therapy.....Just DONT MISS!!!
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
