fan clutch
Old Jul 30, 2009 | 06:03 PM
southerman's Avatar
fan clutch
ok, throw the serpent belt today it snapped two bolts on the fan hub behind the fan clutch, took whole fan assembly away from engine,so how do you take the fan away from the clutch, when i try to turn the big nut on the fan it turns the fan.
Old Jul 30, 2009 | 09:37 PM
roughstock's Avatar
nut is reverse thread. Turns clock wise to take off. I use a air hammer on edge of nut to loosen, then used BIG channel lock on front of pulley to hold it still then used big wrench to break it loose.
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
