Fan belt squeal??
Old 05-23-2011, 08:31 PM
wellmax's Avatar
Fan belt squeal??
almost each time i shut my motor off in my 2005, 2500 dodge diesel truck the fan belt will squeal. Truck has 45K miles
I replaced the fan belt with a gates heavy duty belt but the noise is still there.
i looked at the pulleys, they looked clean, did not see any build up on any of them.
do all dodge diesels make this noise
i have only had the truck for a few months
the belt that was on the truck when i got it started to make noise at around
41K miles it was starting to come apart, so i replaced it
the belt makes no noise when the truck is running.
only time i can hear a noise is when i shut down the motor.
thank,
Old 05-23-2011, 08:36 PM
pquevill's Avatar
It's a common occurance with all Dodge Cummins. The engine when shut off comes to an abrupt hault, while the components are still turning which gives the chrip sound. You're fine. I have had 2 Dodges (VP44 & CR) and both have been that way.
Q
Old 05-23-2011, 09:03 PM
pquevill's Avatar
Q
Old 05-23-2011, 11:09 PM
nickg's Avatar
my 01 and 03 both did it until I changed the belts to good year gaterback...no chirp
Old 05-24-2011, 12:20 AM
sr4440's Avatar
here's the TSB that covers it
http://dodgeram.info/tsb/2006/09-004-06.htm
Joe
Old 05-24-2011, 01:14 AM
ctd4stan's Avatar
I have an '04 and it use to chirp until I changed it to a Gaterback
$25 at autozone.
Old 05-24-2011, 06:32 AM
hoot's Avatar
I like the chirp
Old 05-24-2011, 03:31 PM
wellmax's Avatar
Thanks for your replys,
I will not worry about the belt noise, but next time may buy a gater belt.
have always been a gates belt dude, but it may be time to upgrade.
cannot believe it, but even mama likes the sound of my cummins diesel running.
She really likes the good fuel mileage compared to the old 2500 chevy with 350 engine, that loved every gas station it met.
Old 05-24-2011, 08:35 PM
Mr Jerry's Avatar
I have to say the Alt pulley with the clutch does cure the problem,, I had it done before my 06 went out of warranty, hasnt made a peep since.
Old 05-24-2011, 09:00 PM
hoot's Avatar
It's not a problem. It's simply a characteristic.
Old 05-27-2011, 05:19 PM
stroker101's Avatar
mine will do it just a little if i leave the A/C on when shutting the engine off. other than that, never
Old 05-27-2011, 06:10 PM
Mr Jerry's Avatar
Your right its not a problem anymore, because the problem is fixed.
bannerd
04-03-2012 10:30 AM
thesheriff
02-20-2009 08:42 AM
greenrig
05-28-2007 04:30 PM
signkrazy
08-07-2006 04:43 PM
Kuntry
08-30-2005 12:57 AM
Quick Reply: Fan belt squeal??
