Exhaust Manifold Removal
Old 05-09-2006, 09:44 PM
probaja's Avatar
Any tips out there for getting the Exhaust Manifold off, as im replacing with an HTT 3 piece. Having trouble getting to the bottom middle bolts as they turbo is in the way. Any help out there???
Old 05-09-2006, 10:56 PM
piperca's Avatar
Remove the turbo? I think you'll find you will have to remove it at some point during the install.
Old 05-09-2006, 11:42 PM
probaja's Avatar
I was hoping not too, it at all possible? Is this the only way???....I was thinking this was going to be easy......
Old 05-10-2006, 12:11 AM
caffecapri's Avatar
I reached some of the tough bolts from underneath....a long wrench and a rubber mallet to break them loose. Decent room from there.
I left my turbo where it was...just unbolted it and removed the plastic air ducting.
Old 05-10-2006, 09:15 PM
Tate's Avatar
I took off the intake hose from the filter, and unbolted the turbo from the manifold first, let the exhaust and high pressure pipe to the intercooler support the turbo. Used a ratchet or a doubled up wrench to break the bolts loose. Used the ratchet and an allen key with a wrench looped on to install the new manifold. I don't know if the HTT comes assembled (think it does), but the ATS I got came disassembled. We clamped one of the end sections to the original manifold. Heated up the center section in the oven, slipped it on to the end section clamped to the old manifold, then slipped in the last end section. Let it cool and then it'll hold its shape during installation. Only needed a dead blow to get the first bolt started on the end sections, rest was cake.
Old 05-12-2006, 03:25 PM
Yukon Dodge's Avatar
Good time to drill and tap that new exh manifold for an EGT if you don't have one already...then no chance for the filings to go into the turbo.
shaft
07-04-2010 02:20 PM
jj3500
01-01-2010 09:04 PM
D45
08-28-2008 09:26 PM
trik396
06-01-2008 07:04 PM
wolf359
07-09-2005 09:29 AM
Quick Reply: Exhaust Manifold Removal
